Voodoo4 and Radeon!
    Posts: 1086 from 2003/3/24
    I have a Voodoo4 PCI in my Peg2 running well under MOS, but i have serios problems with the Voodoo in Linux, i have also a Radeon 7000 AGP., is it possible to run the Peg with both Cards at the same time? Voodoo for MOS and the AGP Radeon for Linux?
  • »30.12.04 - 10:21
    Posts: 1932 from 2003/10/19
    From what I know that Radeon must be PCI and the Voodoo AGP to do that. Something in the OF looks for the ATI card in AGP and if found makes it enabled first.
  • »30.12.04 - 11:04
    Is someone using a Voodoo4 Card with Linux?
    [ Edited by ThePlayer on 2004/12/30 22:48 ]
  • »30.12.04 - 11:21
    Posts: 261 from 2003/3/13
    I was using a voodoo4 AGP with linux.
    The problem is, you will not be able to
    use HW 3D accel under PPC linux.
    Gr,
    Felix.
  • »30.12.04 - 14:36
    analogkid
    Posts: 719 from 2004/11/3
    have you used the tdfx driver with X ? I've seen it on a Voodoo4 only with framebuffer driver, the other didn't work.
  • »30.12.04 - 15:17
    I don't need the HW 3D accel.
    I have used the tdfx driver with X, how can i switch to the framebuffer driver?
    Here is my x86config http://www.pegasosforum.de/viewtopic.php?p=6623#6623
    and here a pic how my problem looke like: http://www.pegasosforum.de/download.php?id=52
  • »30.12.04 - 15:38
