What is this?
    DSLCC
    Posts: 246 from 2003/5/14
    Two pegs in one case - one running MorphOS and the other Linux to enable printing?? :)
     :-P
    Pegasos 1 G3 MorphOS 1.4.5* Mac G4 Sawtooth 1Ghz Tiger 10.4.1* Both Rock! :-D
  • »08.11.04 - 20:01
    wolfe
    Posts: 118 from 2003/8/7
    2 motherboards Peggybacked?  :-D
  • »08.11.04 - 21:09
    Posts: 2070 from 2003/6/4
    A microcluster??? well one PEG mobo could run as thin clien served by
    the other mobo, internally coupled by the GEthernet would make a nice
    microcluster.
    conclusion: That's going to be hot Sh¡t!
  • »08.11.04 - 22:35
    DSLCC
    Zylesea wrote:
    A microcluster??? well one PEG mobo could run as thin clien served by the other mobo, internally coupled by the GEthernet would make a nice microcluster. conclusion: That's going to be hot Sh¡t!
    Now I feel ignorant... :) Lots of techno-babble here. Can someone explain what a thin client is?  :-?
  • »09.11.04 - 01:29
    hooligan
    Posts: 1948 from 2003/2/23
    It's either a coffee maker or a Cambodian streetlight-testingapparatus
  • »09.11.04 - 02:28
    DSLCC
    Making coffee is pretty mission critical! We sure that dual peggy's are up to it? They sure would not get warm enough to make coffee.  :-o
  • »09.11.04 - 03:02
    serge
    Posts: 725 from 2003/2/20
    very interesting :-)
    I did the same idea with a PEG and an A1200 for AGA games ;-)
    2 machines; 1 monitor, 1 mouse and 1 keyborad and an auto switch that's all.  :-P
  • »09.11.04 - 03:49
    DSLCC
    That would be cool! :) Maybe a peg/mac or peg/pc box with a built in kvm switch. But the projects in the pics need lots of work to get the slots cut out, etc. :) Or maybe it's an AmigaOne/1200.
     :-x
    [ Edited by DSLCC on 2004/11/9 0:06 ]
  • »09.11.04 - 04:05
    gunne
    Posts: 441 from 2003/2/25
    Hi
    Yes a microcluster.
    As what it says, Seems like the small guy - power as the big :-)
    Gunne
    Best wishes, Gunne
  • »09.11.04 - 06:53
  • dan
    dan
    Posts: 55 from 2004/4/11
    Seems like it´s a cluster of four Pegs in one case! :-o
  • »09.11.04 - 07:46
    gunne
    dan:
    Yes !
    Gunne
    Best wishes, Gunne
  • »09.11.04 - 08:25
    Gunne, that is really cool stuff! :-D I think that can become a kind of topseller!
    I guess the client mobo can be powered off and on by the master board? That would make some good sense. You only add the power of the client(s) when you need it.
    We know Linux is clusterable but the question that arises immediately: Will be MOS 1.5 ready for clustering? I remember the bplan dnet cruncher was rumoured to be some cluster...
  • »09.11.04 - 08:29
    gunne
    Hi
    Ok, and Thank You. It is an experiment so far. And yes, one powersupply, one board boots, the other having delay and boots later. Only one board can turn of the system, the other cant run halt, shutdown etc. But the aim is to not turn of the system of course. Its easely moveable.
    We haven't run openmosix or anything similar yet, but distcc works I know.
    Edit;
    About MorphOS, not for this experiment now.
    I do really like MorphOS, its the quickest and most responsive os I ever used, and probably also ever will come to use. And also looking forward to use it forward of course. It really does put the fingertip onto how something is that happens directly.
    Gunne
    [ Edited by gunne on 2004/11/9 13:28 ]
    Best wishes, Gunne
  • »09.11.04 - 08:43
