Posts: 2072 from 2003/6/4
Yes and no. Every router can serve MOS once the route has been set up, but it's difficult to set up the router using a MOS browser. I failed with MOS trying to configure my router (smc barricade), the configuration interface used some java script Voyager was not able to handle correctly, hd to do the configuration using Firefox.
