1Gb DDRam memory modules
    pegasosuser
    Posts: 138 from 2004/4/9
    hello all,
    who has experience with 1Gb DDRam modules?, it works good?, brand?.
    Cor van Londen.
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »06.10.04 - 14:50
    AyoS
    Posts: 410 from 2003/8/13
    I have a GET ddr 2700 CL 2.2
    with Part#0343 AE25d1284T-6
    This is a 1 Gig Dimm that I got at a steal, works well
    I believe. Most of the time all I use with MOS 1.4.1
    is about 100 meg. I have filled my Ramdisk with over 512 meg of
    data without any noticible problems. I know that this dimm wont work
    with MSI athlon 64 boards as they can only handle 512 per dimm.
    works with PegII appearently
    katos1
  • »06.10.04 - 19:59
    pegasosuser
    TNX! Katos1
    I wil go look for that
    Greetings Cor van Londen.  :-D
  • »07.10.04 - 17:56
    AyoS
    But don't spend too much on one, since you posted
    I have done a little more research thru google and have found
    nothing but complaints about this Dimm. Does anyone else
    use a 1 Gig Dimm on their Peg II??
    I wish I had a way to do a full test to be sure it would work
    well for you.
    Katos1
  • »08.10.04 - 00:43
  • pOS
    pOS
    Posts: 220 from 2003/11/14
    I have a 1 GB module in my PegII; it's from MDT. Don't know exact identifier. Got it from my Peg Dealer (http://www.knabe-bueroservice.de/). You might get in contact...
  • »08.10.04 - 03:14
    Posts: 9 from 2004/4/17
    From my experience, 1 GB ram is the max on the pegasos 2 (I have 2x1 GB sticks, and 2x512 sticks, the computer will not even get sync on the gfxcard with more than 1 GB)
    The ram is REG ECC PC2100, make unknown though
    Christian Langeland
    DozerN on EFNet and ArcNet
  • »13.10.04 - 07:40
