Daily use differences Peg 1 and Peg 2?
    DrZarkov
    Posts: 142 from 2004/3/21
    I'm a Peg II User. Now I've got a Peg I, unfortunally without documentation, and no installed system. I've tried the commando from my PegII handboot boot /pci/ide/cdrom boot.img, but this didn't work. Is there a different command for booting from CD-Rom?
    Secon question: The connection for the power-buttom I simply tried out, successfully. Are the other pins (loudspeaker, reset, USB, etc) at the same place as in the PegII?
  • »10.10.04 - 15:59
    Frostwork
    Posts: 302 from 2003/4/18
    Hi, DrZarkov!
    The Peg2 uses an other boot.img than the Peg1, but they are
    both on the CD. Just boot the correct one and it'll work...
    The pins should be at the same place, but maybe who really
    knows should tell you ;)
    cheers
    frostwork
  • »10.10.04 - 16:08
    ironfist
    Posts: 254 from 2004/4/22
    The image is called bootpeg1.img.
  • »11.10.04 - 15:33
    DrZarkov
    Unfortunally this was not the problem, I'm afraid.
    If the motherboard-layout is almost the same as at the PegII, I've connected the harddisk (an old 2 GB Seagate) at IDE0, the CD-Rom at IDE1, of course with the right cable, and of course both as "master". I've used this command for booting:
    boot /pci/ide/cdrom bootpeg1.img
    And I get this result:
    error: error while trying to load or boot
    No I really don't know anymore...
  • »11.10.04 - 15:52
    DrZarkov
    I've just tried:
    ls /pci/ide gives
    cd@0,1 (<== when connected as slave at IDE0)
    disk@0,0
    so it will recognize it. The preinstalled auto-boot finds the old Linux x86 file-system on the disk and can't do of course anything with it but display a kind of roaster.
  • »11.10.04 - 16:07
    Posts: 126 from 2003/2/17
    boot /pci/ide/cd@x,y bootpeg1.img
    with x= 0 for primary channel and 1 for 2ndary channel
    with y=0 for master and 1 for slave
    only use 80 pins plate ribbons and connect the master at the end of
    the ribon. The end connector which is the furthest from the middle one
    must be connected to the motherboard?
    [ Edited by FALCON1 on 2004/10/11 20:09 ]
  • »11.10.04 - 16:07
    DrZarkov
    Well, now it starts to boot, there really is a difference: PegII you write ../cdrom and PegI ../cd
    But now it says it can't recognize the filesystem. I've tried two different CD-Roms. Maybe the hd is too slow for the Pegasos?
    [ Edited by DrZarkov on 2004/10/11 20:28 ]
  • »11.10.04 - 16:24
    DrZarkov
    Booting from CD-rom was not possible, maybe the fault lies in the Morphos 1.4.2. CD, bundled with my PegII? So I've put the harddisk into my PegII, I've installed Morphos, then I've put the harddisk back into the PegI, and - It works!!
    CD-Rom ist working, too! I don't know what I did wrong, but problem solved, the way doesn't count;-)
  • »12.10.04 - 16:00
