router?
    Robert
    Posts: 331 from 2003/5/12
    Hi folks,
    Now that I have broadband, can anyone reccommend a router, preferably in the UK?
    Ideally, I'd like something that is straightforward to set up and cheap. :-D
    Robert.
  • »06.10.04 - 11:18
    ChatDEau
    Posts: 248 from 2003/4/4
    @Robert
    I'd recommend that you buy a Lynksys router. There are plenty of other good brands, but I never had problems with this one and it's quite easy to setup and has a web interface to do so.
    Hope it helps!
    Fred
  • »06.10.04 - 14:02
    Robert
    @Fred:
    I'll check it out, thanks.
    Robert.
  • »06.10.04 - 14:05
    pegasosuser
    Posts: 138 from 2004/4/9
    hello Robert,
    I have good experience with Linksys and the Sitecom.
    greetings Cor van Londen.
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »06.10.04 - 15:02
    Robert
    Hi folks,
    Something like this (click) maybe?
    Or a Sitecom ADSL ROUTER WITH 4 PORT SWITCH DC-201?
    [ Edited by Robert on 2004/10/7 14:22 ]
    Robert.
  • »07.10.04 - 10:45
    Posts: 2077 from 2003/6/4
    I have a SMC Barricade 7004 router and firewall. It was only 39 EUR (or was it only 35?, don't remember exactly - it was cheap anyway), is slim easy to configure and got good ratings.
    Configuration is bad with Voyager (both, the QNX one and the MOS one) but firefox did the trick.
    It has 4 ports and can handle dsl and cable modems. I didn't found anything I disliked on it yet.
    [ Edited by Zylesea on 2004/10/7 16:11 ]
  • »07.10.04 - 12:10
    Posts: 43 from 2003/9/1
    Hello,
    Even I recommend a Linksys router. I once started with a Router branded by ZoNet but the support was bad, the Firmware was buggy and I had a lot of problems.
    Now I own a Linksys WRT54G Router and that piece of Hardware really rocks. It also supports Wireless LAN and if you do an Firmware upgrade (from their Web page) you will then be able to lock WLAN access to the Router's Setup, be able to use WPA-SPK with TKIP or AES encryption. The ports from outside are all placed to STEALTH mode so whenever someone portscans you everything is hidden. The Firmware used on it is also based on Linux and you can access the Firmware sourcecode as well.
    Currently the best Routers for normal Homeusers are either Linksys or Netgear. I for now haven't regret buying a Linksys router and even if you don't plan to use WLAN get one anyways (you can turn it on or off in the Settings) you might use it one day.
  • »07.10.04 - 13:14
    pegasosuser
    the Sitecom 10/100Mbps xDSL/Cable Router 45 and have 4 ports and 1 Wan or totaal 5 ports
    easy to configuration.
    greetings Cor van Londen.  :-D
  • »07.10.04 - 17:47
