Wacom Tablets
    bigdan
    Posts: 63 from 2003/4/12
    Any infos welcome concerning tablets support on Peg'I or Peg'2 under MorphOs 1.4.x (and software used with tablet like FxPaint2, etc..).
    Anybody test usb Wacom recents models like ?
    x Graphire 3 (normal (A6) and XL (A5) models)
    x Volito (A6)
    x Intuos2 (lots of models in usb or serial)
    Thanks in advance.
    bigdan
  • »26.01.04 - 13:03
    Tcheko
    Posts: 540 from 2003/2/25
    Hello bigdan,
    You will find more information at this place : http://www.e3b.de/usb/main_supported_e.html
    Morphos uses Poseidon stack.
    Regards,
    Tcheko
  • »26.01.04 - 13:26
    liquidbit
    Posts: 408 from 2003/10/12
    I wouldn't create a new post when bigdan already did..
    I couldn't find anything on the a Poseidon web-site over a Pen Tablet support list.
    What I did was the following, I borrowed two Wacom Tablets (here in Europe you don't have other choice) from a computerstore. The Volito(cheapest Wacom Tablet) & the Graphire3 (double the price).Both A6.
    Poseidon recognized both but the Volito was the one which was working, the Graphire3 did nothing on the screen...
    I tested them on DebianPPC aswell and they working both!
    The only problem on MOS is that it works like a mouse.For example if you pointing to the tablet edges, the pointing arrow remains in the middle, only when you wave with the pen on the tablet it starts moving.
    Do I need some extra drivers/classes for the PenTablets ?
    Please help me quick because I only have one week to test them both!
    Regards,
    Liquidbit
  • »27.09.04 - 05:32
    liquidbit
    Here some screenshots...
    Wacom Volito
    http://www.geocities.com/liquidbit/pegasos/wacom-volito-001.jpg
    http://www.geocities.com/liquidbit/pegasos/wacom-volito-002.jpg
    Wacom Graphire3
    http://www.geocities.com/liquidbit/pegasos/wacom-graphire3-001.jpg
    http://www.geocities.com/liquidbit/pegasos/wacom-graphire3-002.jpg
    ...an example of my test drawings with the Wacom PenTablet :-D
    http://www.geocities.com/liquidbit/pegasos/wacom-example.jpg
    [ Edited by liquidbit on 2004/9/27 11:35 ]
  • »27.09.04 - 07:34
    realstar
    Posts: 298 from 2003/2/24
    I am sucessfully using an e3works Stylo
    on MorphOS. Everything works including
    pressure and absolute movement.
    You can see the Stylo tablet here:
    http://www.e3works.com/stylo.html
    A simple review can be found here:
    http://www.extremereviews.net/data.php ?recordID=126&page=1&type=review
    To liquidbit:
    I tested graphire2 before and could not get
    any results. The other tablet appears to
    be trying to work as a hid device so check
    if it's on absolute mode in the poseidon
    settings as relative input could act like
    a mouse...
  • »27.09.04 - 11:41
    liquidbit
    thanks realstar,
    I will continue my investigation, like I said only Wacom you can find here in Europe. :-(
  • »27.09.04 - 12:55
    liquidbit
    After a deep investigation the conclusion is as follows:
    THEY DO NOT WORK ON MOS
    ..now i have to keep one tablet ...yeah for my mac  :-(
  • »28.09.04 - 12:58
