Posts: 2833 from 2003/2/8
Try the following:
I. Make sure you have connected your speakers to the correct auio out. There is mic, audio out, and headphones-out. headphones are also a greenish color. (have made this mistake myself.
II. Check AHI again.
1. Settings->System Settings
2. Main Prefs Windo_>AHI
3. Check Pegasos:16 bit stereo++
3.a) Volume 100%
4. Save (if needed) exit.
III. Look at the settings in PegasosMixer.
1. Menu->Utilities->Exchange
3. Select PegasosMixer (if it isn't there, it's been moved from wbstartup, and need to be found and put back in the proper place).
4. From Exchange, use "show interface."
5. Look for the volume control of each item, but more importantly, see if anything is muted. Note again, the headphone jack on the back of your Peg is also a green color.
6. You should be able to save/exit.
I hope that was of some help.
