UAE guide for MorphOS?
    MorphDelf
    Posts: 274 from 2004/2/20
    Hello.
    I have to admit, that I am not so technical person and would like to know how to get UAE to run on MorphOS?
    There should also be a guide on-line on how to install MUIrexx and AREXX for MorphOS. VoyagerPPC needs it and etc other programs aswell.
    Please help,...
    Regards,
    Michal, www.amigaworld.org
  • »24.08.04 - 16:54
    Posts: 1932 from 2003/10/19
    There is a guide for AREXX install, at least there was. I thinks its just a matter of placing the libs from WB 3.X into the libs dir and a few small other things. The MUIREXX is a bit harder, but someone here had a link to a UAE that had everything in it needed to run once you put it on your hard drive.
  • »24.08.04 - 18:28
    Frostwork
    Posts: 302 from 2003/4/18
    Hi!
    Yes it's on DJBase' homepage!
    Sorry don't have a link....
    Good luck!
    Anyway it's time for UAE-JIT....
    bye
    frostwork
  • »24.08.04 - 18:34
    Found it, here ya go. http://www.djbase.de/computer/pegasos/projekte/index.php?projekt=1
  • »24.08.04 - 18:40
    MorphDelf
    It works, but very unstable :((the 68k version got sound,
    but got problems with it too :( the mos version just crash
    if sound is enabled.
    Would be nice to have a real UAE working. A Linux port for
    example?
    Regards,
  • »26.08.04 - 00:38
    I'm sure that the ones we have are based off the Linux sources like all the others are. Try going to the main WinUAE page. You will find a link to the Experemental UAE site and can get the exe for another build by some other guy for 68k Amiga. It works well too, but no sound.
  • »26.08.04 - 08:30
