printer Canon BJC-3000
    pegasosuser
    Posts: 138 from 2004/4/9
    I have a printer the Canon BJC-3000 whit paralel and USB port.
    this printer would not working on Me system.
    can You thel Me what I can do?
    Turboprint would not working.
    TNX!
    Cor van Londen.
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »23.08.04 - 22:34
    Spidey
    Posts: 568 from 2003/2/24
    Hi Cor,
    Look at the other thread :-)
    HERE
    Bye,
    Spidey
  • »24.08.04 - 08:36
    Jupp3
    Posts: 1193 from 2003/2/24
    I've succesfully printed with my Canon BJC-4300 printer on MorphOS with GraphicsPublisher (No separate TurboPrint installed)
    But it was long ago - Back then I had Pegasos 1...
  • »24.08.04 - 09:03
    Spidey
    And I had the problem of 'inverted colors' from the beginning. Back then I had a Peg 1.
    With my Peg 2 it wasn't different untill I tried the solution of completely installing TurboPrint.
    And at last I can use GraphicPublisher with normal colors! :-)
    Bye,
    Spidey
  • »24.08.04 - 10:53
