Pegasos II G4 Cooling Solutions
    Leon
    Posts: 93 from 2003/11/28
    THe default fan on the G4 CPU Card that comes with Pegasos is too noisy. I would like to mount another cooling solution but first I would like to have some information about it:
    - At which temperatures does the G4-1000 operate? When idle and high loaded?
    - Is a fan really needed? There are very successful northbridge coolers like Zalman NJ47, can I use them?
    http://www.1coolpc.com/nb47j1.htm
    http://www.silentpcreview.com/News+article-sid-301-mode-thread.html
    - Does the G4 have a self protection against high temperatures? Like shutting itself down or slowing down the system like the P4 CPU's? So if I apply a passive cooler, will the G4 explode without letting me know?
    - Are the holes around the G4 CPU based on a standard? Will a cooling solution like this fit?
    http://www.spirecoolers.com/hdd.asp?prodid=12
    It's a great thing that Pegasos comes out with Cool Computing slogan. Well it is cool, but at the same time noisy, just because of the CPU fan. I want Cool and Noisy Computing :)))
    Proud owner of:
    Efika
    ABIT ATI 9200SE AGP 128MB
    40GB Samsung Hard Drive 5400rpm
    PowerMac 3.1 G4 350Mhz "Sawtooth" AGP
  • »15.07.04 - 11:04
    Wishmaster
    Posts: 342 from 2003/6/29
    Gfx card coolers should fit.
    Pegasos PPC
  • »15.07.04 - 15:43
    Robin
    Posts: 741 from 2003/2/24
    I'm using the Zalman with no additoinal fan since 5 month
    now and my peg is on 24/7 ... it gets quite hot but I've
    not yet suffered a crash from heat (I believe) ... since
    a few days I've it running in a desktop with only a 200W
    PSU with a small fan and it's still running without probs
    and as it seems we get no real summer here in germany this
    wont change ;-)
  • »15.07.04 - 17:29
