Webcam "TwinkleCam Pro"
    pegasosuser
    Posts: 138 from 2004/4/9
    Hello all! I have a question
    i have a WebCam TwinkleCam Pro 300K
    this Cam would not mounted in USB (Poseidon)
    have You a answer? tanks!
    greetings from: Cor van Londen a PEGASOSII user!
    [ Edited by Darth_X on 2004/7/9 7:14 ]
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »09.07.04 - 14:55
    Bifford
    Posts: 280 from 2003/2/24
    Does the cam show up at all in Poseidon? (ie shows but is not bound to anything?).
    If so open a Shell and type MosSys:C/USBDevLister
    then copy and paste the result here and we'll take a look ;-)
    TTFN
    Bifford
    Bifford the Youngest
  • »09.07.04 - 18:55
    Posts: 1931 from 2003/10/19
    I've also had problems with my webcam. It refuses to work at all in MOS. If you get it solved be sure to post how!
  • »10.07.04 - 16:10
    Bifford
    Ok, for some reason pegasosuser could not post his usboutput here so he sent me an email with it instead.
    The weird thing is that he sent it to my OLD u-net address!!???
    Damn lucky i checked that account and didnt just delete all the mails (which is 99% spam/porn mails, and with 2000 odd every time i check u can see why i often just delete the lot without checking them first....!)
    so here is his output:
      Poseidon DevID  : 'USB Camera-05A9-A518-n/a-00'
      Product Name    : 'USB Camera' (ID: A518, Vers: 0102)
      Manufacturer    : 'OmniVision Technologies, Inc.' (Vendor: 05A9 (OmniVision Technologies, Inc.))
      Serial Number   : 'n/a' (USBVers: 0110)
      Device State    : fullspeed connected hasaddress hasdevdesc isconfigured
      Device Address  : 2
      Class/Sub/Proto : 0/0/0 (<unknown>)
      Current Language: English (United States)
      Supported Langs : English (United States)
      1 configuration(s):
        Config 1 (Configuration 1)
        Attrs   : bus-powered
        MaxPower: 500 mA
        3 interface(s) for this config:
          Interface 0 (Vendor interface (0)) (ID: '00-00-FF-00-00')
          Alternate Setting: 0
          Class/Sub/Proto  : 255/0/0 (Vendor)
          1 endpoint(s) for this interface:
            Endpoint 1 (isochronous <-[ IN)
            MaxPktSize: 0
            Interval  : 1
          Alternate settings:
          Interface 0 (Vendor interface (0)) (ID: '00-01-FF-00-00')
          Alternate Setting: 1
            MaxPktSize: 129
            Interval  : 1
          Interface 0 (Vendor interface (0)) (ID: '00-02-FF-00-00')
          Alternate Setting: 2
            MaxPktSize: 257
            Interval  : 1
          Interface 0 (Vendor interface (0)) (ID: '00-03-FF-00-00')
          Alternate Setting: 3
            MaxPktSize: 385
            Interval  : 1
          Interface 0 (Vendor interface (0)) (ID: '00-04-FF-00-00')
          Alternate Setting: 4
            MaxPktSize: 513
            Interval  : 1
          Interface 0 (Vendor interface (0)) (ID: '00-05-FF-00-00')
          Alternate Setting: 5
            MaxPktSize: 641
            Interval  : 1
          Interface 0 (Vendor interface (0)) (ID: '00-06-FF-00-00')
          Alternate Setting: 6
            MaxPktSize: 769
            Interval  : 1
          Interface 0 (Vendor interface (0)) (ID: '00-07-FF-00-00')
          Alternate Setting: 7
            MaxPktSize: 897
            Interval  : 1
          Interface 1 (Audio interface (1)) (ID: '01-00-01-01-00')
          Class/Sub/Proto  : 1/1/0 (Audio)
          0 endpoint(s) for this interface:
          No alternate settings.
          Interface 2 (Audio interface (2)) (ID: '02-00-01-02-00')
          Class/Sub/Proto  : 1/2/0 (Audio)
          Alternate settings:
          Interface 2 (Audio interface (2)) (ID: '02-01-01-02-00')
            Endpoint 2 (isochronous <-[ IN)
            MaxPktSize: 32
            Interval  : 1
      Google: http://www.google.com/search?q=usb+0x05A9+0xA518
    anyone any the wiser?????????????
  • »10.07.04 - 21:11
