webcam!!
    pegasosuser
    Posts: 138 from 2004/4/9
    I like to know wich webcams are compatible with pegasos :-?
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »08.07.04 - 13:51
    Posts: 199 from 2004/2/9
    Do you use a USb webcam ? It should work
  • »08.07.04 - 14:04
    This can help :-)
    http://www.e3b.de/usb/main_supported_e.html
  • »08.07.04 - 15:45
