USB card reader working with MorphOS?
  • JBB
    Posts: 32 from 2004/5/27
    The one I was using on my PC doesn't work unfortunately (it's a multi "7 in one")...
    It gets detected okay as 4 separate drives (okay so far, similar to the behaviour on PC), but when I plug a memory stick in, all I get is SCSI errors in the log...
    Any ideas?
    Otherwise, do you know of any card reader that works with the Peg? (at worse just SD)
    Cheers,
    JBB
  • »22.06.04 - 07:38
    MarK
    Posts: 641 from 2004/1/25
    AFAI checked many USB devices, some does and some doesn't work. But all of them were correctly recognised. It's probably because of the massstorage.device, which seams to be too 'young' to know all the modern devices. It usualy worked well under PegXLin, but I hope, it will work also with the MorphOS 1.5... (imo, I don't need anything else, than just the updated massstorage.devide...)
    Bye, MarK.
  • »22.06.04 - 07:57
    TheMagicM
    Posts: 1220 from 2003/6/17
    It works here!!! (MOS 1.4.2, Pegasos I pre-april)
    Before I shipped off my Pegasos to a new user.. I had a 6 in one USB card reader... I was able to mount my smart disk and copy images etc. Worked GREAT. Heck, even the USB keychain memory card thingy worked..surprised a few ppl when I showed my Peggy at a Amiga club. LOL
    Here is my card reader I have (click below):
    Smartdisk Universal Reader
  • »22.06.04 - 11:19
    tokai
    Posts: 1289 from 2003/2/25
    if it does not work from start try to modifie massstorage settings a bit.
    Try to play around with "Simple SCSI:" and/or "Translate CMD6->CMD10:" etc.
    My USB-Memory-Clock didn't worked first, then i played around a bit with the settings and et voila! :-) And make sure you use the latest Poseidon from platon42.de
    regards,
    tokai
  • »22.06.04 - 12:55
    Piru
    Posts: 609 from 2003/2/24
    ST Lab USB Card Reader All-in-1 U-231 works for me, at least MMC cards.
    Needs fat95 from aminet installed, naturally. I have 'No Initial Reset', 'Simple SCSI' and
    'Translate CMD6->CMD10' ticked.
  • »22.06.04 - 19:05
    Furvert
    Posts: 83 from 2004/4/20
    Sorry if I missed it. I think the first question that needs to be asked though is did you update to the latest version of poseidon and fully activate it. This really makes a big differance.
    Especailly with massstorage devices.
  • »23.06.04 - 08:28
