Does a Peg II with a g4 fit into a standartd micro ATX case?
    magnetic
    Posts: 2129 from 2003/3/1
    Ironfist:
    Yeah, I guess you are right. Are you using an AGP gfx card? If so is it hard to fit?
    magnetic
  • »22.06.04 - 04:29
    Posts: 1932 from 2003/10/19
    poundsmack wrote:
    would a peg fit in THIS?
    That is one sharp looking case. I am thinking of ordering the silver one if I can find out for sure if it works or now. I would think the ATX version would be fine though.
    EDIT: The only US reseler has it as a custom system only for $1600. Thats a damn shame.
  • »22.06.04 - 10:08
    ironfist
    Posts: 254 from 2004/4/22
    Jepp. I use a Radeon 9200SE Lowprofile AGP-card.
    It wasn't that hard to fit, just be very careful.
    The 20 powercables sure are stiff. :)
    The other cables all fit between the CPU-card and
    the graphics card.
  • »22.06.04 - 10:17
