My G4 cooling solution
    Posts: 159 from 2003/10/24
    You talk about a new firmware. I can't find it on bplans site. When will it be relased to the public?
    --Mithalas
  • »03.03.04 - 15:07
    gunne
    Posts: 441 from 2003/2/25
    Mithalas:
    Dont know. But my guess is, when bplan find its time to do.
    Gunne
    Best wishes, Gunne
  • »03.03.04 - 15:30
    cecilia
    Posts: 459 from 2003/8/30
    what about this idea from Cooligy???
    "Fluid cooling". :-o
  • »03.03.04 - 15:50
    Posts: 2 from 2004/3/2
    sorry for the french link :)
    This is the right one xlr8
    And macbidouille
  • »03.03.04 - 22:13
    MarK
    Posts: 641 from 2004/1/25
    @ _4afc_
    Hmm, really interesting. But it's talking only about 7450 and 7455, not about 7447/7457, that is the current solution in Pegasos G4. Looks, like motorola just 'tried' to support some temperature measurements... But G3 machine is IBM product, and it should contain a bit different TAU, that might work well... Have to check this.
    Bye, MarK.
  • »04.03.04 - 05:04
    Posts: 20 from 2004/2/26
    It is talking about MPC7447A, that will the future solution in Pegasos G4. I just disappointed. In press releases we can read:
    New Power Management Features
    1-Clock frequency can be changed dynamically
    2-Temperature sensing diodes included to monitor die temperature
    But in MPC7450 Family Chip Errata for the MPC7447A we can read that "The TAU is not implemented on the MPC7447A."
    I can't understand that.
    Autor of the BTR_8x8 - Video Capture program for MOS/QNX4/Windows.
  • »05.03.04 - 05:52
    tarbos
    Posts: 221 from 2003/4/19
    It seems to be a different unit that is being introduced with the 7447A.
  • »05.03.04 - 11:12
    antibike
    Posts: 112 from 2003/3/5
    @Gunne
    hmm the new G4 PegII has another cooling solution that
    makes not such extrem noise? is there only another fan
    or has it also another cooler?
    can you make a picture? :)
  • »05.03.04 - 11:23
    Posts: 2728 from 2003/2/24
    I just wanted to make a follow-up on my initial post in this thread. I have now had the CPU going at 100% non-stop for several days, crunching RC5 keys, and it runs very cool. Everything works fine!
  • »07.03.04 - 19:42
    Wishmaster
    Posts: 342 from 2003/6/29
    It's borken, kaputt, nix funktioniere, no funciona.
    The IBM G3 temperature unit does work.
    Pegasos PPC
  • »21.06.04 - 15:14
    Posts: 54 from 2004/6/16
    Why not use a Peltier and run the G4 at, say, 10 degrees C? Vary the power supplied to vary the temp (not too cold our you might end up with heat expansion failure when you switch it off)and the water cooling systems cyphon the heat from the other side away, and allow for a big, slow, fan to pull it all out.
    Maybe a bit over the top I guess, lol ...
    -~= Amiga Cats don't get Microsoft worms! =~-
  • »21.06.04 - 20:33
