UAE problems!
    BigGun
    Posts: 150 from 2004/6/18
    I'm trying to run some games with UAE but I'm stuck right at the start.
    I use UAE 0.8.22 without gui.
    As Kick I'm using a kickfile of my old A4000.
    OK here myu questions/problems:
    1) The Kick works but the floppy game is never loaded. It always shows the insert disk animation.
    2) How can I run something in window mode?
    My main problme is that I could not find a proper description of the config options.
    Here is my test config:
    floppy0=Work:Soft/UAE/ADF/BattleSquadron.adf
    kickstart_rom_file=Work:Soft/UAE/ROMS/kick31.rom
    32bit_blits=yes
    cpu_speed=real
    cpu_type=68040
    cpu_compatible=yes
    gfx_framerate=3
    gfx_width=320
    gfx_height=240
    gfx_lores=yes
    gfx_linemode=double
    gfx_center_horizontal=smart
    gfx_center_vertical=smart
    gfx_fullscreen_amiga=false
    sound_output=normal
    Many thanks in advance
    Gunnar
  • »20.06.04 - 15:38
    BigGun
    Argll, I found the reason why the games don't boot.
    I've unziped my adf collection into ram:
    Unfortunatly unzip removed read rights of the files.
    Copying the files with Ambient to the harddisk worked but
    all files were of size 0 now.
    The *magic* behavior of Ambient did cost me some hours ... :)
    Anyway I can now start the games but I still have a feww problems:
    1) UAE seems the be _very_,_very_ slow.
    How can I play Amiga500 games with my Peg II G4 ?
    2) Can some please point me to a list of config options?
    How do I setup joypad or joystick emulation?
    Thanks
    Gunnar
  • »20.06.04 - 16:26
    Posts: 261 from 2003/3/13
    Why aren't you using UAE with MUIRexx GUI ?
    That way you can easily setup UAE to smoothly
    run a500 games.
    Bye,
    Felix.
  • »20.06.04 - 17:05
    BigGun
    Erm, I had problems starting the GUI.
    I figured now out that it works as soon as I start rexx. :-)
    Gunnar
  • »20.06.04 - 17:28
    BigGun
    I can't help but UAE is still very slow.
    The sound plays with *normal* speed but gfx jumps and is slow.
    When I disable sound then gfx is ok.
    Any ideas how to fix this?
    I've a Peg II G4, with 512MB, radeon 7000, onboard sound
    I'm running UAE 0.8.22 special edition by djbase
  • »20.06.04 - 18:16
    I had the same troubles you have, eventualy
    i played a lot with the settings, and i got a
    good result with nice gfx and good sound.
    My pegII G4 card died a while ago, i am
    waiting for the repairs, so i can't tell you
    exactly what changes you have to make
    to get it running smooth, all i can say is
    that i had spaceballs demo and some a500
    games running with good speed and sound.
    Just play a lot with the settings, specially
    the sound settings.
    Bye,
    Felix.
  • »20.06.04 - 18:43
    Posts: 1931 from 2003/10/19
    I've never got it to work myself. If sound is on mine is slow like
    yours, if its off its too fat to be playable. I gave up. Now I try it
    and I cant get any disks to run like you say you had problems with.
  • »20.06.04 - 22:06
    Wishmaster
    Posts: 342 from 2003/6/29
    It's not slow.
    The Sound emulation is causing stalls.
    We need an UAE version with fixed sound support.
    Use 16 bit 48kHz stereo modes. They are the fastest I think.
    Pegasos PPC
  • »20.06.04 - 23:57
    Spidey
    Posts: 568 from 2003/2/24
    hi everybody,
    Does anyone use the Catweasel with UAE?
    I heard you can connect original Arcade joysticks on them.
    Does that work in UAE?
    Bye,
    Spidey
  • »21.06.04 - 10:45
    Wishmaster
    UAE is loading zipped ADFs.
    No need to uncompress them.
    Pegasos PPC
  • »21.06.04 - 17:50
