Booting from CD with arguments problem ;(
  • Leo
    Leo
    Posts: 428 from 2003/8/18
    After having made some MorphOS boot CDs, I'm trying to boot from CD with ramdebug argument but it won't work...
    when typing "boot /cd boot.img", the system boots from CD without any problem...
    But when I try to add an argument after boot.img, no matter what I add, I get the same error...
    For example, if I type "boot /cd boot.img ramdebug",
    I'll get the error:
    "no such file boot.img ramdebug
    error: can't open file for reading or writing"
    I got pre-april Peg1 - firmware version 0.1b107
    Leo.
  • »20.06.04 - 17:16
    ChatDEau
    Posts: 248 from 2003/4/4
    I really don't know, but I suggest to try:
    boot /cd "boot.img" ramdebug
    Fred
  • »20.06.04 - 18:03
  • Leo
    Leo
    Same error...
    ('no such file "boot.img" ramdebug')
  • »20.06.04 - 20:03
    ultraspec
    Posts: 94 from 2004/1/29
    I've had similar problems in the past with test boards. Most of the time when your file ends with 'img' it's ok to add parameters...
    You can try boot.img;1 ramdebug
  • »21.06.04 - 13:30
  • Leo
    Leo
    My file ends with img ;)
    After some discussion on IRC, it seems that the problem may come from the antic version of my firmware...
    But I can't find peg1 firmware update anywhere ;((
    Leo.
  • »21.06.04 - 13:54
