Realtek ethernet card
    GK_LKA
    Posts: 481 from 2004/3/28
    I have a Realtek 10MBit PCI Ethernet card (RTL8029AS) and I've problems with using it. I tried to configure my existing, and with onboard working ADSL internet connection to this card in MiamiDX (just have selected the rtl_8139pci.device), but it couldn't connect. If I make a new hw definition, miami can't open the device/unit if I want to ask device for SANA-II parameters. What's wrong? I bought this card because of it was on the compatibility list. (The reason: I have a (***) pc too, and I want to share my ADSL connection to it. (PS: Why is the onboard 1Gbit card still not supported??)
    [ GK / LKA Team ]
  • »02.06.04 - 18:31
    Posts: 1081 from 2003/3/24
    Then try this Driver it's for Grex but should work with Pegasos http://grex.amigaworld.de/daten/rtl_8029pci_15.lzh
  • »02.06.04 - 19:05
    GK_LKA
    It works! Thanks a lot! You saved my life :))
    [ GK / LKA Team ]
  • »02.06.04 - 20:08
    My pleasure!
  • »02.06.04 - 20:31
  • JKD
    JKD
    Posts: 456 from 2003/4/4
    That's great...but why anyone doesn't use a cheap external router for this is beyond me!
    It'll certainly be faster than 68k emulated application and they come with other goodies such as firewall, traffic blocking etc.
  • »02.06.04 - 21:08
    GK_LKA
    Because this card was free for me :)
    [ GK / LKA Team ]
  • »02.06.04 - 22:09
    Posts: 1520 from 2003/2/24
    If driver is 68k maybe it could be ported to MorphOS? :-)
  • »02.06.04 - 23:22
    Posts: 1932 from 2003/10/19
    That driver dint work because the 8139 driver is for a 100Mbit card with the 8139 chip. The card you have is the 10Mbit card and uses the 8029 chip. Not the same at all.
  • »03.06.04 - 00:03
    GK_LKA
    Yes, it is clear, but then webmasters should modify the FAQ-s on the MZ about this topic.
    BTW why is the onboard 1Gbit card still not supported??
    [ GK / LKA Team ]
  • »04.06.04 - 22:28
    Well my guess the Gigabit isnt ready yet is its not a top thing. The other one works, and your not going to get Gigabit over the net.
  • »04.06.04 - 23:44
