Can't Play Audio CD's.
    matt3
    Posts: 784 from 2004/2/10
    Finally got round to using my peg 2 again. Put an audio cd in for the first time. Morphos doesn't mount or recognize the cd. I have one cd burner and one dvd rom both play all other media's perfect. CD plays perfect in other systems and tried multiple music cds...
    Any ideas?
    btw, using peg2, latest firmware, latest MOS update....
    Matt
  • »25.05.04 - 21:22
    Posts: 1521 from 2003/2/24
    Try AmiNetRadio or CD Player. There is no built-in support for audio CDs in MorphOS.
  • »25.05.04 - 22:03
    matt3
    Thanks! Songplayer worked perfect.
    I thought the os would mount the cd, like my amigas.
    Thanks again!
    Matt
  • »25.05.04 - 22:13
    Posts: 1932 from 2003/10/19
    Take a look on morphos-news.de and get the cdplayer app. It will do the trick. The CD is mounted, it just doesnt show up at all. The cdplayer app will play it just fine. I ran into the same problem when I first got my system.
  • »25.05.04 - 22:14
