Which U160 SCSI Card ?
  • pOS
    pOS
    Posts: 220 from 2003/11/14
    The compatibility lists do not contain any information on U160 SCSI controllers (160 MB/sec.). Can anyone tell me, which one can be used with Peg-II ?
  • »08.05.04 - 23:07
    magnetic
    Posts: 2129 from 2003/3/1
    AFAIK There is no U160 card for Pegasos. However, you are in luck we have some nice Symbios 895 cards UWSCSI2 @ 80/mb sec that are fully tested and working with PEagsos and Morphos and Linux.. send me an email or PM if you want one.. Only $39.95 + shipping...
    magnetic
  • »12.05.04 - 19:33
    Furvert
    Posts: 83 from 2004/4/20
    I can give a thumbs up for the cards Magnetic is selling.
    I bought one and it works great in my Peg2. :)
  • »12.05.04 - 23:24
  • pOS
    pOS
    Could you give more info, please ?
    How is this card called ?
    Does it support booting from HDD / CD on Peg-II ?
  • »13.05.04 - 07:49
    Neko
    Posts: 301 from 2003/2/24
    If you can find a 32-bit PCI U160 controller, with drivers for Linux, then you'll be fine.
    For MorphOS - you have to be kidding :)
    Neko
    Matt Sealey, Genesi USA, Inc.
    Developer Relations
    Product Development Analyst
  • »13.05.04 - 14:50
    magnetic
    THe cards I have are LSI Logic cards. Very high quality UWSCSI up to 80mb/s!! Works great with MOS. Should be bootable never tried. Also works very well in Linux and Mac On Linux. For $39.95 + $15 worldwide air shipping you cant beat the deal.
    As far as U160 unless you are doing RAID arrays for Video work or for Servering Net content why would you need that much speed on a desktop machine?
    magnetic
  • »13.05.04 - 16:24
    Posts: 126 from 2003/2/17
    U160 and U320 boards are PCI 64 bits cards
    concerning 895 boards, I've a tekram board based on this chipset, it
    works quite fine under mos
    but : (test it please magnetic)
    * If I set the sync bit on a HD with SCSIconfig, the symbios.device
    crash on boot (do the test with an empty hard drive)
    * I got hwerror If I try to boot from CD or HD from the SCSI
    controller...
  • »13.05.04 - 22:01
  • JKD
    JKD
    Posts: 456 from 2003/4/4
    "* If I set the sync bit on a HD with SCSIconfig, the symbios.device
    crash on boot (do the test with an empty hard drive)"
    I can confirm I had the same problem on my Peg I. I had to manually set sync. after the fact...dunno about magnetic.
    Steve
  • »13.05.04 - 23:36
    magnetic
    I've removed my SCSI card as I was mainly using it for xfering my Amiga drive data. I had to take it out so I could add other pci cards, I ran out of slots - so no testing atm.. :-(
    However, I have sold some to some guys and they probably can give you help with those..
    magnetic
  • »14.05.04 - 04:58
    Posts: 33 from 2003/6/17
    PegII, 512 MB Ram, Radeon 8500, NEC USB-Card
  • »14.05.04 - 08:30
    Furvert
    I have a HP ScanJet 4c connected externally and a Yamaha 8424 cdrw internally on mine.
    I'm using the Symbios 895 cards UWSCSI2 that Magnetic is selling. I did have to buy adaptors for the two connectors on the board. (One internal, 64 pin, one external, 64 pin VHDCI.) I converted them to 50 pin. I have to boot with the scanner turned off but it works great with Betascan.
    The only problem I have so far is that the CDRW doesn't read for now. I think that's just a setting or maybe a dosdriver like on the Amiga.
    Furvert
    A differance that makes no differance is no differance.
  • »14.05.04 - 19:29
    magnetic
    Glad you are enjoying it! Thank you. A few more people have ordered as well and will have theirs soon so more people to give data here! I had a nice Seagate 18gb Baracuda hooked up and it was screaming fast!
    magnetic
  • »15.05.04 - 18:40
