Posts: 2129 from 2003/3/1
The soundcards that work with MOS are the Creative Soundblaster types - Audigy, Live!, value!, and 5.1 afaik. The card MUST have the EMU 10k chipset.
However, the built in AC97 sound is pretty good. Better than most pc built in sound. If you are just using MOS and normal Linux usage this should be sufficient for your purposes. The Only reason I went with a Live! Value is due to heavy CPU load with MOL... but the sound is better, but honestly the onboard sound is nice.
magnetic
