help with printer
    Brumiga
    Posts: 272 from 2004/4/3
    hello,
    this afternoon i have connected my printer, Epson Stylus C60, to the Pegasos 2 to the parallel port with a working bidirectional parallel cable but nothing worked, i only obtained a request to verify my cable. in Settings -> System settings -> Printer i choosed the driver for my printer, Epson Stylus C60, port parallel one and saved. i do not have usb a -> b cable. i have downloaded and installed the latest parallel.device from ftp server. can anybody help me to use my printer on Pegasos 2's parallel port ?
    Brumiga
  • »09.05.04 - 15:55
    Spidey
    Posts: 568 from 2003/2/24
    Hello Brumiga,
    How did you choose the setting of port parallel one?
    I'm at my work now so I can't check it, but if you choose the type Parallel everything else is ghosted. If you choose the type Device, then you mist fill in which device to use on which port.
    Bye,
    Spidey
  • »10.05.04 - 03:59
    Posts: 1932 from 2003/10/19
    Make sure you have the new parallel.device from the beta2 site. Then select type as device and enter in parallel.device in the space. I ended up using USB for my printer though.
  • »10.05.04 - 12:48
