SCSI Card
    Posts: 81 from 2004/3/20
    Here's another 'which card' question? Are there any scsi cards to beware of when trying to interface my old Amy hd to the peg 2? Are there any better suited than others?
    Thanks.
    Harry
    Config: Pegasos II G4 1ghz, 1024mb memory,
    Radeon 9200,160gb hd total, Sound Blaster Live!
  • »07.05.04 - 19:36
    magnetic
    Posts: 2129 from 2003/3/1
    YOu can look on the pegasos specs on the website for cards that work. You are in luck! I have some nice Symbios Logic 895 UWSCSI cards in stock for $39.95 NEW! (these cards are worth over $100) It works great with MorphOS and gives you internal and external UWSCSI @ up to 80mb/s also backwards compatible with older SCSI 2 and SCSI standards with 68pin to 50 pin adaptor (Such as Amiga SCSI drives) I have one of these cards in my peg2 and use it to access my Amiga 4000 SCSI drives
    :-D
    magnetic
    PM me if you want one or go to
    www.magneticsystemsnyc.com and email me
  • »07.05.04 - 23:38
