Tried twice, once the system started for my surprise.
Second time didn't.
EDIT: Tried with radeon 6950HD, it seems that on cold boot machine starts ok (doesn't matter what card) but after reset is dead again on the same messages.
EDIT2: It's kinda of reproduceable with cold boot and then restart. Checked with 3 different gfx cards. It "feels" like something is missing in initialisation after reset or smth and then it dies.
U-Boo� mole~-be_-2023-01-0y (Ja~ 0y 2023 - 0xz21z2y +0000)
CPU0z P5040, Ve�io~z 2>1, (0xx2040021)
Coez e5500, Verio~z 1>2, (0xx0240012)
Clock Co~fio��a_��K5
CPU0z2200 MHz, CPU1z2200 MHz, CPU2z2200 MHz, CPU3z2200 MHz,
CCBzx00 MHz,
DDRzx00 MHz (1600 MT/>"�х��<_V B
�y~ch�o~ou), LBCz400 MHz
FMA^1z 600 MHz
FMA^2z 600 MHz
QMA^z 400 MHz
PMEz 400 MHz
L1z D-cache 32 KiB e~abled
I-cache 32 KiB e~abled
Ree� Confio}a_��
_o>BRC_)z
00000000z 90e00000 00000000 acac9x00 00440000
00000010z 44x0xc00 ff29a000 68000000 61000000
00000020z 00000000 00000000 00000000 0003000f
00000030z a0000000 00000000 00000000 00000000
Boa�dz CYRUS
36-bi
��ɕ��ing
I2Cz �eady
DRAMz I~i_+������>>>>}i~g SPD
DDRz failed �
��*� SPD f�om add�e�>�j
De�ec_UDIMM CT51264BD160B>C16F
Thee i>�� �a~k o~ CS0 fo>▒���r���Ɂ0>
No*��՝
���(chi�-elec_ 2�ɁCS0+CS1 o~ co~�olle� 0, i~�e�leaving diabled!
�� all DIMM>
�� iden_k��> Memo�y co~����Ɂi~_ɱU�٥�� diabled>
OiB lef� �ma��ed
2 OiB (DDR3, 64-bi ▒1=11, ECC off)
DDR Chi�-SelecJ��Y>��٥�� Modez CS0+CS1
Local B�>▒��Ѿ���ɁRegi>_ɯHHI0 0xE0001001 OR0 0xFFF00010
BR1 0xE1001001 OR1 0xFFF00010
BR2 0x00000000 OR2 0x00000000
BR3 0x00000000 OR3 0x00000000
BR4 0x00000000 OR4 0x00000000
BR5 0x00000000 OR5 0x00000000
BR6 0x00000000 OR6 0x00000000
BR? 0x00000000 OR? 0x00000000
LBCR 0x40000000 LCRR 0xx0010004
L2z 512 KiB e~abled
Co�e~e� Pla�fo�m Cachez 2 MiB e~abled
SERDESz ba~k 2 diabled
MMCz FSLSDHCz 0
>.. -5g E~vi�onme~2ɽ�[j5
Boa�d Reviio~ 2210
SP(/���p4zA3z6Bz43z42
MACz 00z1EzC0zF7zFCz0?
EEPROMz ^XID v0
PCIe1z Roo▒����U�, x4 oen1, �eo> 0xfe200000
01z00>0 - 1002z?244 - Di>��X^▒��Ѿ����5
01z00>1 - 1002z?264 - Di>lay co~�olle�
PCIe1z B}>��j��j
PCIe2z Roo▒�����Y, x4 oe~2, �eo> 0xfe201000
03z00>0 - 111dzx0y2 - B�idoe device
04z01>0 - 111dzx0y2 - B�idge device
05z00>0 - 12dxze111 - Bridoe device
06z05>0 - 1102z0002 - M�l_����� device
06z05>1 - 1102z?002 - I~�u"�٥��5
���02>0 - 111dzx0y2 - B�idoe device
04z03.0 - 111dzx0y2 - Bidge device
04z0x>0 - 111dzx0y2 - Bridoe device
04z10.0 - 111dzx0y2 - B�idoe device
PCIe2z B}>��j�
5
PCIe3z diabled
PCIe4z diabled
Looki~g fo� VOA
PI^Sz 0xfc000x0x
videobooz Boo_��� PCI video ca�d b}>�b2�c_��
�b"�٥�� 0
Beoi~ BIOS POST
E~d BIOS POST
Se_˝
VESA Mode
Fo�d �e�ui�ed VESA mode
Abo��o ej��� 2?y
P��� �
z��@mode
Ooj��� 4y431 (0xc11?)
OK
XSize = 1024 YSize = ?6x Bae = 0xx0000000
mmiobae = 0xx0000000
I~z e�ial
O��z e�ial
E��z eial
IDz ^XID v0
SNz 116400015
UIDz 442y431001y10050acx0a0x0a0x00000
E��a�az �����% x�
B}Z� da_�����z��z�����3xz1?
CRCz xxdca1a
SCSIz E��o�z SCSI Co~����ɡ) no2�չ�
^ez I~i�ializing Fma~
MMC �eadz dev # 0, block # 5223, co�� 12x >>>
Fma~1z U�loading mic�k��� ve�ion 106>1>0
MMC eadz dev # 0, block # 57223, co�������
Fma~2z U�loadi~o mic�ocode ve�io~ 106>1>0
U��i~g PHY @ 3
Tui~o PHY @ ?
FM1@DTSEC5, FM2@DTSEC5
USB0z USB EHCI 1>00
������� bu>�2��device>>> 4 USB Device() foud
USB1z SB EHCI 1.00
������� bu>�2��device>>> 3 USB Device() fo�d
SATA0 (1.5 Ob�)
� a"�٥��5
SATA1 (3 Ob�)
E>�K'SCSI Con�olle�() ~o� foud
X5000~ boo��rho>�EDEBUG�L�W=i~�
o>h�M boob����Ɂve�io~ 1.17
Boo�ing f�om DH0
T�yi~g �o load "boocy�u>��>img" f�om "DH0z">.>
ߥ�� �o load "boo�>img" f�om "DH0z".>>
Loaded "boo�J��" f�om "DH0z", boo_˝���j
41>810
41>x11
41>x12 ABox 1.30 (2>>2018) � 1999-2022 by Ralph Schmid *�����Y
b��Օ��,Teemu Suikki, Ha��y Si~�oe~
1.x64 P5040I~i�IDE@0z D�ive �een�
41>x69 P5040Ii_1z D�ive �ee~�
41>y50 P50x0 SATA Dive�@0z PIO Mode 4
4#rʪ� P50x0 SATA D�iver@0z UDMA Mode 6
41>y61 P50x0 SATA D�ive�@1z PIO Mode 4
41>y64 P50x0 SATA D�ive�1z UDMA Mode 6
Srʺ � Ha~dleIn�e��u0z Sig~a�ure i>r�� 0xeb140101
41>975 Ha~dleI~_������ Sig~a_ɕ)���*ѕ�C!S�ʺ�^ Ha~dleI_����� Phy �eady
41>yx2 ide>device@0z HL-DT-ST DVDRAM OH24^SD5 <CDROM~
42>023 ide>device@1z ATA-HD TS256OSSD230S <DIRECTACCESS~
�>12y HandleI~_ɮ��1z Sig~a_�YJ� now 0x00000000
42>133 HandleI~�er�u��@1z Sig~a�u�e u�da�e
42>13 Ha~dleI~_�����L/Phy �eady
�r���� ide.device@1z Mou� <DH0~
42>36 ide>device@1z Pa�_ѥ���"!0~ Do>U�����53465300 Boo�P�i 0
4Cr���� ide.device@1z Mou� <DH1~
42>444 ide.device@1z Pa�_�Z��"!1~ Do>U�����53465300
43.532 u>���i>device@0z Mo��B%50~
43>536 �>���i.device@0z Pa�_�io~ <HDIMG0~ Do>U�� 0x444f5307 Boo%Z��j
4y>4w4 Radeo~z Do~'� k~ow how �
J���+���e � memo�y co~�rolle� of +k Radeo~
4y>4x3 Radeo~z Memo�y ize adju��ed �
���j 5
182.31� LIBChangeVPBitMapz v��ode i>�U115
1x3>44 LIBChangeVPBitMa�z v�ode i>�U115
1x4>514 LIBCha~geVPBitMa�z v�ode i>�U115
C�HU-Boot molsen-beta-2023-01-09 (Ja��2023 - 0x:21z2y +0000)
CPU0: P5040, Ve�ion: 2.1, (0xx2040021)
Co�e: e5500, Ve�io~: 1>2, (0xx0240012)
Clock CofiguratioOj
CPU0:2200 MHz, CPU1z2200 MHz, CPU2z2200 MHz, CPU3:2200 MHz,
CCBzx00 MHz,
DDR:x00 MHz (1600 MT/>"�х���(_V B
��.k�ɽ����), LBC:400 MHz
FMA^1: 600 MHz
FMA^2z 600 MHz
QMA^z 400 MHz
PMEz 400 MHz
I-cache 32 KiB eabled
Re�et Cofiguratio~ Wo�d (RCW):
00000000: 90e00000 00000000 acacyx00 00440000
00000010z 44x0xc00 ff2ya000 6x000000 61000000
00000030: a0000000 00000000 00000000 00000000
Boa�dz CYRUS
36-bit Add�e�ig
I2C: �eady
DRAM: Iitializig>>>>uig SPD
I: failed to �ead SPD f�om add�e�>j
DYW�ѕ� UDIMM CT51264BD160B>C16F
The�e i>�o �ank o~ CS0 for cont�olle� 0>
^ot eough bak(chi-elect) fo� CS0+CS1 on co~t�olle� 0, ite�leaving diabled!
^ot all DIMM>
� idetical> Memo�y co�t�olle� iterleavig diabled>
2 GiB left uma�ed
2 GiB (DDR3, 64-bit, CL=11, ECC off)
DDR Chi�-Select Ite�leavig Mode: CS0+CS1
C!�k�� Bu>▒������� H����_��
R0 0xE0001001 OR0 0xFFF00010
BR7 0x00000000 OR7 0x00000000
L2z 512 KiB e/����5
Co�eet Pla��K�+▒����: 2 MiB eabled
SERDES: bak 2 diabled
MMC: FSLSDHC: 0
Loadig Evi�omet f�om MMC>.> OK
Board Revi�io����j
MAC: 00z04:A3z6B:43:42
SP('��Ҋ�Q�(�27zFC:07
EEPROMz ^XID v0
PCIe1: Root Com�lex, x4 ge1, �eg> 0xfe200000
01z00.0 - 1002z244 - Di>��X^▒���ɽ����5
01z00.1 - 1002z264 - Di>��X^▒���ɽ���5
PCIe1z Bu� 00 - 01
PCIe2z Root Com�lex, x4 geOb���� @ 0xfe201000
03:00>0 - 111d:x092 - B�idge device
04:01.0 - 111dzx0y2 - Bridge device
05:00>0 - 12d8:e111 - Bridge device
06:05>0 - 1102z0002 - Multimedia device
06:05>1 - 1102z002 - I�� device
��҂���j���"��ʒjɥ��"�٥��5
04:03.0 - 111dzx0y2 - Bridge device
04:08>0 - 111dzx0y2 - Bridge device
04:10>0 - 111dzx0y2 - B�idge device
PCIe2z B}>��j�
5
PCIe3: diabled
PCIe4: diabled
Lookig for VGA
PINSz 0xfc000x0x
v'bdeobootz Bootig PCI video card bu>�b2չction 0, device 0
Begi BIOS POST
Ed BIOS POST
Se�tig VESA Mode
Fou�d �e�ui�ed VESA mode
Abo�t to e� mode 27y
About to ge� mode
Got mode 49431 (0xc117)
OK
XSize = 1024 YSize = 76x Bae = 0x80000000
mmio_ba�e = 0xx0000000
RK�e�ial
Outz erial
E��z e�ial
S^z 116400015
UID: 4429431001910050acx0a0x0a0800000
Er�ataz ����� % x�C!ե�� da�e: 2016/04/25 0y:3x:17
CRC: xxdca1a
SCSI: E��o>'SCSI Cotrolle�() ot fou�d
Nez I/ѥ���饹g Fma�H�H��j �ead: dev # 0, block # 57223, cout 12x >>>
T+�1: U�loadig microcode ve�io 106>1>0
MMC read: dev # 0, block # 57223, cout 128 ...
Fman2: U�loadig mic�ocode ve�io~ 106>1>0
Tu�ig PHY @ 3
Tu�ig PHY @ 7
USB0z USB EHCI 1>00
����ig bu>�2�� ��٥���>> 4 USB Device() foud
USB1z USB EHCI 1>00
����ig bu� 1 for device�>.> 2USB Device() foud
SATA0 (1.5 Gbp)
E a� device
SATA1 (3 Gb�)
Q.�K SCSI Cot�olle�() ot foud
SK��=4��� loader ver�ion 1.1?
��ѥ�g from DH0
T�yig to load "bootcyu>��]>J��" f�om "DH0z">>>
%��Zg to load "boot>img" from "DH0:"...
�+��� "boot>img" f�om "DH0z", bootig>>>
1rD�
18>4x3
1x>484� ABox 1.30 (2.>201x) � 1999-2022 by Ralh Schmidt, Emma�el Le�ueu�, Teemu Suikki, Ha��y Sitone
18>536 P5040I/�%0z Drive �re�et
18.541� P5040IitIDE@1z D�ive ��e�et
1x>628 P50x0 SATA D�ive�@0z PIO Mode 4
1x.632� P50x0 SATA D�ive�@0z UDMA Mode 6
C�HU-Boot mol�e-beta-2023-01-09 (Ja 0y 2023 - 0x:21z29 +0000)
CPU0z P5040, Verion: 2.1, (0xx2040021)
Co�e: e5500, Ve�ion: 1>2, (0x80240012)
Clock Cofigu�tion:
CPU0z2200 MHz, CPU1z2200 MHz, CPU2z2200 MHz, CPU3:2200 MHz,
CCB:x00 MHz,
DDR:800 MHz (1600 MT/>"�х �a�e) (A�ych�o�ou�), LBC:400 MHz
FMAN1z 600 MHz
FMA^2z 600 MHz
QMA^z 400 MHz
PMEz 400 MHz
L1z D-cache 32 KiB eabled
Re�et Co�figura�ion Wo�d (RCW):
00000000z y0e00000 00000000 acac9x00 00440000
00000010: 4480xc00 ff2ya000 68000000 61000000
00000020: 00000000 00000000 00000000 0003000f
Boa�d: CYRUS
36-bit Add�e�i~g
I2Cz ready
DRAM: Iitializing....u�g SPD
I: failed to �ead SPD from add�e�>�j
De�ected UDIMM CT51264BD160B>C16F
The�e i>�o �ank o~ CS0 fo� cont�olle� 0.
^ot eough bank(chi�-elect) fo� CS0+CS1 o~ co�t�olle� 0, ite�leavi~g diabled!
^ot all DIMM� are identical> Memory co�trolle� ite�leaving di�abled>
&z� left uma�ed
2 OiB (DDR3, 64-bi�, CL=11, ECC off)
DDR Chi�-Select Ite�leaving Modez CS0+CS1
Local B�>▒��t����� H����_��5
BR0 0xE0001001 OR0 0xFFF00010
L2z 512 KiB e/����5
Coreet Platfo�m Cache: 2 MiB eabled
SERDES: bak 2 di�abled
MMC: FSLSDHC: 0
Loadig Evi�o�met from MMC>.> OK
Boa�d Revi�ion 2210
MACz 00z04:A3z6B:43:42
SP('��Ҋ�Q�(�37:FC:07
EEPROM: �% v0
PCIe1z Root Com�lex, x4 oe1, reg� @ 0xfe200000
01z00>0 - 1002z244 - Di>��X^▒��t�lle�
01z00>1 - 1002z264 - Di>��X^▒��t�olle�
PCIe1z B��00 - 01
PCIe2z Root Complex, x4 oen2, reg� @ 0xfe201000
03:00.0 - 111d:x092 - Bridge device
04:01>0 - 111d:x0y2 - B�idge device
05z00>0 - 12dx:e111 - B�idge device
06z05.1 - 1102z002 - I�t device
04:02.0 - 111d:x0y2 - B�idge device
04:03>0 - 111d:x0y2 - Bidoe device
04:0x>0 - 111d:x092 - B�idge device
04z10.0 - 111d:x0y2 - B�idge device
PCIe2: Bu� 02 - 0a
PCIe3z di�abled
PCIe4: diabled
Looki~g fo� VGA
PINSz 0xfc000x0x
videobootz Bootig PCI video card bu� 1, fuctio~ 0, device 0
Begi BIOS POST
Ed BIOS POST
Setting VESA Mode
Fou�d re�uired VESA mode
About to et mode 27y
P��� to oet mode
OK
XSize = 1024 YSize = 76x Bae = 0xx0000000
mmio_bae = 0xx0000000
I: e�ial
Out: erial
E��z e�ial
SNz 116400015
UID: 442y431001y10050acx0a0x0a0800000
E��ataz ����% x�C!ե*� date: 2016/04/25 0y:3x:17
CRC: xxwdca1a
SCSIz E��o�z SCSI Co�trolle�(s) ot foud
^etz Iitializing Fman
MMC �ead: dev # 0, block # 57223, cout 12x >.>
man1z U�loading microcode ve�io~ 106>1.0
MMC �ead: dev # 0, block # 57223, co�t 12x >>>
Fman2z Uploadig mic�ocode ver�io~ 106>1>0
T��ig PHY @ 3
Tu�ig PHY @
USB0z USB EHCI 1>00
����ig bu� 0 for device�>>> 4 USB Device() foud
USB1: SB EHCI 1.00
scan�ing bu>�2�� ��٥��>> 2USB Device(s) foud
UQ0 (1.5 Ob�)
CE at device
SATA1 (3 Ob�)
E��o�z SCSI Co�t�oller() �� foud
X5000~ boo�mo�ho� ED���LAGS=iit
SK��=4��� loade� ve��ion 1.17
��ѥ�� f�om DH0
T�ying to load "bootcyru�lu�>img" f�om "DH0z"...
T�ying to load "boot>img" f�om "DH0z">..
Loaded "boot>img" from "DH0:", booti~g>>>
23.6y2
23>6y3�
23>6y4 ABox 1>30 (2.w.201x) � 1yy9-2022 by Ral�h Schmidt, Emmauel Le�ueu�, Teemu Suikki, Har�y Si~to~e
23.w45 P5040IitIDE@0: Drive p�eet
�&�50� P5040IitIDE@1: D�ive eset
23>x3x P50x0 SATA Drive�@0z PIO Mode 4
23>x42 P50x0 SATA Drive�0: UDMA Mode 6
