Posts: 1597 from 2012/11/9
Karrottow - I don't know where you got the spec that the
A1058 17" iMac has a
Radeon in it, because it is supposed to have a
Nvidia GeForce 5200 (Ultra?) 64MB VRAM card in it, as does the
A1076 iMac the 20" screen model of the same era, which is a totally unsupported GFX card/family for MorphOS.
So, as
jacadcaps has already pointed out check the MorphOS hardware compatibility page thoroughly, before making a bad decision to buy hardware that is just not, and
never likely to be supported - seeing as it has a
Nvidia GFX system!
MacMini 1.5GHz,64MB VRAM, PowerBooks A1138/9 (Model 5,8/9),PowerMac G5 2.3GHz(DP), iMac A1145 2.1GHz 20", all with MorphOS v3.19+,Airport,Bluetooth,A1016 Keyboard,T-RB22 Mouse,DVD-RW-DL,MiniMax,Firewire/USB2 & MacOSX 10.4/5
