The internet connection is not working
    Posts: 18 from 2025/1/5
    I tried connecting a network cable to my PowerMac G5, but I couldn't establish a connection. I tried automatic dhcp configuration and manually setting IP addresses, but nothing happens. I have no idea if the computer port is working or how to check it, but here's what my router and system settings look like
    3C16iup-Gf-OYv-Bkb-NHi-E1cn-Dq-Zra-Cx-Fd-Zb-QVU16i-Yc-WOm-MQREsr-Swt-Iq3uu7g-IM6OPCDZCa-I7x-B-L7d1x W4saw-Fn-AUxd-ECP1hmw-C68v-P-9TYQv-WGri-XCC2o-Rc-LTm-Te7jvc7oph-Slhk-Y-y1-XUmlu5s1Mk-Fyx-Tbyqn-Be-Pj
    Maybe I'm just setting something up wrong?
    [ Edited by olevenets 23.12.2025 - 16:29 ]
  • »23.12.25 - 16:28
    ChrisC
    Posts: 36 from 2025/3/1
    The ethernet ports on these desktops do not function as there is no driver.
    Power Mac G5 11,2 Dual 2GHz
    ATI X1950 Pro 256MB
    2GB RAM
    500GB Storage
    MorphOS 3.19 (Licenced)
  • »23.12.25 - 23:20
    Posts: 3298 from 2003/3/5
    @ChrisC
    Sungem implies this is an AGP G5. We've got drivers for those.
    @olevenets
    How did you verify that it's (not)working? Try a ping to 192.168.100.1.
  • »24.12.25 - 00:42
    ChrisC
    jacadcaps wrote:
    @ChrisC
    @olevenets
    Eek, missed that bit
    ATI X1950 Pro 256MB
    2GB RAM
    500GB Storage
  • »24.12.25 - 08:07
    I'll try using the new patch cord I already ordered from the store, as my old cable is having some problems connecting to PC. If that doesn't work, I already found the Realtek RTL8139C, and I hope it work on my PowerMac G5 7.2
    [ Edited by olevenets 25.12.2025 - 15:18 ]
  • »25.12.25 - 15:16
    Today I connected my PowerMac to a new cable and the internet worked right away. Issue resolved :)
  • »28.12.25 - 06:40
