Moderator
Posts: 2514 from 2003/2/24
asrael22 wrote:
So seems the HD4350 doesn't work.
x8 vs x16 should make no difference.
Now the make sure (before you buy 14 other cards):
- did you check the card in a PC
- if not, does the G5 have a working OSX install, if yes boot with both NVidia and Radeon installed and check if the radeon is showing in system information
- what kind of screen did you use, very high and very low resolutions can cause issues
- when booting does the G5 ramp up the fans after time and does the caps lock LED still work will tell wether MorphOS has crashed or is still running
