PCIe GFX card HD4350 only showing 256 MB
    asrael22
    Posts: 445 from 2014/6/11
    Hi.
    I received another HD4350. From the sticker on the card it should have 512 MB RAM, but in MorphOS it shows only with 256 MB. At first I wanted to return the card. But then I have seen the sticker. Now I'm not sure who is right. :D
  • »17.10.25 - 12:22
    Posts: 2563 from 2003/2/24
    Both.
    The cards only reports 256MB when operated in 32Bit mode.
    Same with my R5 230 and it's 2GB.
  • »17.10.25 - 15:49
    asrael22
    Can they operate in other than 32 bit mode in MorphOS?
    [ Edited by asrael22 17.10.2025 - 21:31 ]
  • »17.10.25 - 20:31
    asrael22
    OK, forget the question. In a 32bit OS supposedly not.
  • »18.10.25 - 04:59
    analogkid
    Posts: 716 from 2004/11/3
    Did you some benchmark comparisons between your 7,3 and the 11,2?
  • »18.10.25 - 08:18
    asrael22
    Unfortunately I can't make a real comparison. I realized that both my 11,2 are 2,3 GHz.
    But are there no benchmarks available?
  • »18.10.25 - 12:30
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    I did some Linux benchmarking DualCPU 2,3 GHz AGP vs. Dualcore 2,3 GHz PCI. at that time with stress-ng, but unfortunately did not save the results.
    RAM-centric benchmarks were faster on the PCIe G5 (no surprive, DDR1 vs. DDR2) and CPU cache-centric benchmarks a little bit, but not much. What was worth the upgrade for me was much less noise on the PCIe G5.
  • »20.10.25 - 19:44
