does MorphOS support composite video on the G4 Mac Mini?
    stvcmty
    Posts: 8 from 2025/1/6
    Does MorphOS support the composite video output on the G4 Mac Mini? Apple sold a DVI to Composite/S-video adapter for the G4 Mini (and the x86 Minis with DVI). I could use a DVI-HDMI cable and a HDMI to composite adapter but I think using the feature built in by apple would be cleaner if it worked under MorphOS.
    My use case is to use MorphOS to display content and route the composite into an RF modulator so I can check the content from any TV in my house.
    Thank you,
    -Stv
    Mac Mini G4 1.42 GHz
    eMac G4 1.25 GHz
  • »08.08.25 - 12:45
    Posts: 3298 from 2003/3/5
    I don't believe that's ever been tested.
  • »08.08.25 - 15:57
    Posts: 1090 from 2004/9/23
    -Stv
    Just install a VNC server on your MorphOS system and a client app on your phone/tv. This case you even can control your system and the display will be in HD without artefacts, jitter and sharpness issues.
    [ Edited by geit 08.08.2025 - 18:05 ]
  • »08.08.25 - 17:05
