MorphOS Developer
Posts: 1076 from 2004/9/23
Sounds like a loose or broken connection on the RAM sockets.
Try removing and inserting the memory bars a few times. This will clean the contacts. If available spray some IPA (Isopropanol aka 99.9% Alcohol) onto the sockets and insert the ram a few times to clean the pins.
Also check if the memory bar locking mechanism is working properly. The bars should be firmly in position without any wiggle.
[ Edited by geit 27.05.2025 - 13:02 ]
