Need a new gfx card for Morphos 3.19 and AmigaOS 4.1
    Posts: 12494 from 2003/5/22
    > stick to a Radeon X1600, X1550, X1300 if you
    > want full 2D/3D on MorphOS and 2D on Linux.
    Aren't those cards 3D-supported on Linux? And why no X19x0?
    > I don't know how well the Radeon HD 5450 is supported on Amiga OS 4.1
    R3xx to R9xx is 2D-only in OS4.
  • »18.02.25 - 18:57
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    Technically they are, but OpenGL 2.x only which for Linux terms means there are not many apps which will profit from 3D acceleration. Also with current Xorg Server the desktop won't use 'GLAMOR' (3D hardware) acceleration either per default but 'EXA' which is less capable. You can force GLAMOR via an user generated /etc/xorg.conf, which seems to work fine on R500 cards, but the user needs to be able to generate such an xorg.conf. ;-)
    X19x0 is R500 and would work as such but it's big (and loud) so it will probably give you a hard time crammig it into an X5000 next to a dual slot RX 470.
    Bigger problem on Linux howerver is that current mesa versions (24.2.0 and above) won't work on Big Endian hardware at all due to issue #11933.
  • »18.02.25 - 20:00
    Sounds plausible, thanks.
    > X19x0 is [...] big [...] so it will probably give you a hard
    My comment #2 has links to solutions to that:
    - using the 3rd, 4th or 5th PCIe slot (x1) with an x16-to-x1 adapter
    - using the 2nd PCIe slot (x4) with an x16-to-x4 cable
    Both X1900 and X1950 have been reported to fit.
    Pity.
  • »18.02.25 - 20:51
    Posts: 123 from 2022/7/1
    ernsteiswuerfel wrote:
    bearerofthetorch schrieb:
    I want to use my Radeon 5450 HD and add another 2D-3D for Morphos specially and of course for Fienix.There are so many models that I don't know really.
    As Andreas said you currently can't use 3D on MorphOS on the Radeon HD 5450. You will have to wait until the TinyGL project is completed.
    For the time being stick to a Radeon X1600, X1550, X1300 if you want full 2D/3D on MorphOS and 2D on Linux. _If_ you do that be sure to replace your HD 5450 with a newer Radeon like the RX 470 which is well supported on Amiga OS 4.1 and will not get detected and used by MorphOS.
    Or you simply wait until the TinyGL project is finished and get away with 2D/3D on MorphOS and Linux. However I don't know how well the Radeon HD 5450 is supported on Amiga OS 4.1 as I don't own a machine capable of running OS 4.1.
    Sorry I rectify,
    My Graphics card is a Radeon 7700,as shown in the title bar of AmigaOS 4.1.
    Hope this helps
  • »25.02.25 - 11:12
    Sorry I rectify,
    Hope this helps
  • »25.02.25 - 11:18
    sacc-user
    Posts: 43 from 2012/5/2
    sailor wrote:
    @bearerofthetorche:
    as Andreas said, it is impossible to have one card with 3D acceleration on MorphOS, AmigaOS and linux.
    look here:
    AmigaNG – kompatabilita HW s AmigaOS, MorphOS a linux ( Czech )
    Amiga NG - compatibilité matérielle avec AmigaOS 4, MorphOS et Linux ( French )
    Abov are articles about hw compatibility. It explains why you need more cards. Use google translate.
    If you really want only one graphics card, it is possible, but you shoud resign to 3D ( even on 2D ) on some systems.
    Here is article about Sam460LE ( Czech), see paragraph 4 with graphics cards options.
    For X5000 I am not recommend one card solution. Second card fit here. I also have in my Powermac G5 an AmigaOne X1000 two graphics cards.
    @sailor
    Great articles, for me the Sam 460LE was very on point.
    My question is can you define the 1950pro card with more info
    I have found x1950 pro with 512 mem and dddr3,
    and x1950 xt with 256 mem and ddr2,
    and some times no mention of specs
    Please list specs if you can
    I am looking for one card for my Sam460LE and your info leads me to the something 1950 something
    Thanks again for your great articles
    Michael, aka sacc-guy
  • »25.02.25 - 15:06
    > Sorry I rectify, My Graphics card is a Radeon 7700 [...] Hope this helps
    Yes, it really does. First off, I'm astonished that MorphOS can display on your Radeon HD77xx at all (as you described in several comments), as I've never before read such thing and it really shouldn't, at least going by what's known regarding GPU support of MorphOS. Can anybody else confirm that MorphOS somehow/somewhat works (at least to some extent) on GCN1-based graphics cards?
    So, if your GPU luckily isn't TeraScale2 but GCN1, which is 3D-supported by OS4 (with A-Eon drivers), then you're off the hook as you can keep this card for OS4 in the primary slot and just need to add to another slot a card 3D-supported by MorphOS and Linux, which would be R5xx-based, as has been mentioned numerous times in this thread.
  • »25.02.25 - 15:54
    XT has somewhat faster GPU than Pro. And for MorphOS at least, 256 MiB VRAM is the limit anyway, so that a 512 MiB VRAM card will show only 256 MiB. Memory type can be largely ignored I'd say.
  • »25.02.25 - 16:15
    sacc-user
    Many thanks for the info!
    I got the 1950 pro, but new issue
    the card works in my 5000 in os4 and morph cd boots (smile)
    but not in my sam460LE, when plugged in on the Sam at power on it just shows a black screen? (sigh)
    any clues
  • »25.02.25 - 23:11
    Posts: 465 from 2019/5/9
    any clues
    Do you see only black screen and nothing else? No U-Boot output?
    - at first check if graphics card 6-pin power connector is correctly plugged
    - if you have other card working with Sam460LE, in U-Boot menu set Video Options / x86 BIOS emulator to slow
    if anything not works, you should post here serial debug log.
  • »26.02.25 - 12:20
    OK so...
    May I go to buy a R5xxx one? Where can I do it? Want to buy as soon as possible.And is this suitable and compatible with my AmigaOS 4.1,Morphos and of course Linux/Fienix?
    I want you folks make it clear.
    [ Edited by bearerofthetorch 01.03.2025 - 08:44 ]
  • »01.03.25 - 07:42
    any clues
    Apart of this technical and useful stuff...I want to make a clear statement here,My possible new graphics card must be able to show 320x240 or 320x256 screen for MAME,Turbografx and Amiga emulators at its most.
    That's primordial for me because since Amedia France is a great company but didn't took much attention when they revived my dormant 5000 back on the summer of 2021.640x480 is for pcs like 320x240 resolutions for my A1-X5000
    Thank you for your understanding.
    Anyway: Is there a way possible to define and use 320x240 on Morphos 3.19?
    Thanks again
  • »01.03.25 - 07:52
    Posts: 2538 from 2003/2/24
    There is the "Monitor" section in prefs which should do just what you want.
    Assuming your monitor can handle that low of a res.
  • »01.03.25 - 08:25
    >> if your GPU luckily isn't TeraScale2 but GCN1 [...] then [...] you can
    R5xx (not R5xxx), which is anything from RV515 (Radeon X1300) to R580+ (Radeon X1950 XT(X)), see https://en.wikipedia.org/wiki/Radeon_X1000_series#Chipset_table.
    > Where can I do it?
    As those cards were released between 2005 and 2007, you will get them NOS at best (but still rarely). It's easier to get them used, so look for them where used stuff is being sold.
    As I wrote, the R5xx-based card is for MorphOS and Linux. That's why you'll have to keep your GCN1-based card in the primary slot for OS4, as I also wrote.
  • »01.03.25 - 15:27
    sacc-user
    any clues
    Thanks Sailor and Andre,
    I worked out that the used 1950pro had an a intermitent power problem..
    So I found a NEW old stock 1950Xt
    everything working now.
    I am still hoping for the morph devs to one day support newer rx cards in the X5000
    so that I don't need two cards but right now I happy using the Sam460LE with a 1950xt.
    now to finally register Morph
  • »01.03.25 - 22:14
    Yeah I saw "Monitores" (In spanish) but the lower is only a 640x480 one.
    Only some I expect final questions.
    Which graphics card is suitable for me to see 2D/3D on AmigaOS4.1 and Morphos 3.19?
    Where can I buy it and how much does it cost?
    Yeah I asume to have 2 graphic cards installed on my X5000.
    Tell me please
    Ah! And I want 3D for Fienix too.
    Are they expensive?
    [ Edited by bearerofthetorch 02.03.2025 - 15:43 ]
  • »02.03.25 - 14:42
    @bearerofthetorch
    I'm afraid we're wandering in circles...
    Please read again slowly and carefully all this topics from #1 to #40 and please, use both google translate and deepl.com for translation to your native language.
    All answers already here.
    [ Edited by sailor 02.03.2025 - 19:54 ]
  • »02.03.25 - 15:18
    > and Morphos 3.19? [...] And I want 3D for Fienix too.
    As sailor wrote, the answers to this have been given many times already in this thread.
  • »02.03.25 - 18:17
    OK Iwill try to read but I have only one good question for you:
    Which ias the best graphics card to use on a daily basis on AmigaOS4.1,Morphos 3.º9 and Fienix? And the price please
    Thanks for all of the support regarded on forums
    I wil stay tuned
  • »09.03.25 - 20:11
    This question is anything but good. And you got the answer already.
    Instead of you asking the same questions over and over again and ignoring the answers, maybe we should do it another way: You tell us in simple sentences (= paraphrase) what you've learned of this thread so far.
  • »09.03.25 - 20:23
    Your MorphOS graphics system diagram has some severe flaws:
    - the "RAVE" field must be changed to "CyberGraphX" (or "CGX")
    - "RAVE" must be another field with an arrow to "CGX"
    - the "GOA" arrow must go to "RAVE", not to "TinyGL"
    - "R100" and "R200" must be moved from "GOA" to "RAVE"
    - "R100" must be deleted from "TinyGL"
    - another "TinyGL (old)" field may be created with an arrow to "RAVE"
    MOSgfx
    MOSgfx-legacy
    @Andreas_Wolf
    please, can you check this diagrams, if they are OK ?
    [ Edited by sailor 22.03.2025 - 18:21 ]
  • »22.03.25 - 15:13
    > MOSgfx
    Looks almost good to me: The arrow from SDL(2) to the graphics card shouldn't be there I'd say. At least I'm not aware that SDL(2) can directly access the GPU without going through CGX.
    Edit: Also, I think that for completeness sake, the CyberGraphX box should also contain Voodoo 3/4/5, Permedia2/2v, SiS 300/305/315/6326 and Volari V3/V5/V8.
    > MOSgfx-legacy
    Looks good to me.
    [ Edited by Andreas_Wolf 02.04.2025 - 12:30 ]
  • »22.03.25 - 16:35
    > MOSgfx
    I am also not sure. But I think, that SDL1 hardware output is direct write to video memory.
    @all
    please, do anybody knows it exatly ?
  • »23.03.25 - 07:21
