Changing boot gong volume
    sergius
    Posts: 47 from 2005/12/6
    Hello,
    after the death of my Macbook, I bought a superb Imac G5 Isight 20 ‘.
    The first thing I did was to install MorphOS 3.19 ;-) . But now I don't have MacOS any more and I want to reduce the start-up gong.
    I think it's possible to do this from the firmware, but I can't remember how.
    Can anyone help me?
  • »05.02.25 - 21:13
    Posts: 12557 from 2003/5/22
    Prefs/Sound has boot chime volume settings since MorphOS 3.12.
  • »05.02.25 - 21:28
    NewSense
    Posts: 1618 from 2012/11/9
    @ sergius - you can still . Dual-Boot MorphOS<->MacOSX the iMac iSight 20" that way, though the link is specifically for the Mac Mini, but the process is basically the same. I know you can, because I use mine that way. 8-D
  • »06.02.25 - 05:07
