EMU10K1 support on a G5
    stvcmty
    Posts: 8 from 2025/1/6
    The MorphOS hardware page lists SoundBlaster Live! (emu10kx) under sound. I have several EMU10K1 based pci sound cards.
    Will a SoundBlaster Live! work in a G5? Is there a way in MorphOS to select the Live! over the G5’s onboard auio?
    Does MorphOS work with the E-mu Audio Production Studio? The APS is EMU10K1 based but has balanced inputs/outputs.
    Can MorphOS use the midi port on a SoundBlaster Live!?
    A G5 seems to be the most finically accessible upgradable MorphOS platform and if I am going to go that route I would like to put in a fancy sound card.
    Thanks,
    -StvCmty
    Mac Mini G4 1.42 GHz
    eMac G4 1.25 GHz
  • »25.01.25 - 01:48
    matt3
    Posts: 782 from 2004/2/10
    The sound blaster and audigy PCI cards both work just fine in the PCIX PowerMac G5's.
    The PCIe sound blaster cards do not work in the PCIe PowerMac G5's.
    I used an audigy card in my 2.7 PCIX for years. Worked perfectly.
  • »25.01.25 - 16:30
