2303 USB Serial adapter binding
    stvcmty
    Posts: 8 from 2025/1/6
    I got a USB PL2303 serial adapter and connected it to my eMac running MorphOS and went to MorphOS Preferences – USB. Preferences showed USB-Serial Controller State orange circle with an ? in it and said Bindings None. I selected serialpl2303.class binding and then selected “I am not dumb”. I clicked restart in USB preferences window. Then the USB-Serial controller comes up with a green circle and serialpl2303.class. Then I am able to run DeTerm and it works with serialpl2303.device.
    Is there a way to make the binding permeant so I do not need to do it every time I restart the computer? I have the problem under MorphOS 3.18 and 3.19.
    Mac Mini G4 1.42 GHz
    eMac G4 1.25 GHz
  • »22.01.25 - 13:22
    Posts: 3311 from 2003/3/5
    What are the vendor and product ids of that device?
  • »23.01.25 - 19:14
    stvcmty
    Vendor: 1659 (=0x067B)
    Prolific Technology, Inc.
    Product ID: 9123 (=0x23A3)
    I got it from amazon because I needed a USB serial adapter that could do 5V or 3.3V https://www.amazon.com/dp/B0C8RJ722Z/
    eMac G4 1.25 GHz
  • »23.01.25 - 23:48
    Thanks, I'll take a look when I have the time.
  • »24.01.25 - 00:55
