Mini powers off after booting into MorphOS
  • phx
    phx
    Posts: 70 from 2005/3/29
    I had this now for the second time within three days: when turning the Mini on for the first time in the day it boots normally into MorphOS, but after a few seconds it switches off without a warning. When I switch it on a second time it seems to run stable for the rest of the day. BTW, the Mini is connected to switchable sockets, which were turned off over night.
    Hardware issue? What can I do? Opening and cleaning? :P
  • »17.11.24 - 07:13
    Tcheko
    Posts: 544 from 2003/2/25
    Clean dust inside cooling parts. Replace thermal paste. At least, this will sort out any thermal throttling/protection.
  • »17.11.24 - 08:31
    Posts: 2220 from 2003/2/24
    I haven't heard that kind of behaviour before, and never experienced such on my three minis. Probably not a software issue at least... I also have my computers on switchable sockets...
    If it's not about dust, maybe PSU or maybe if it's possible to reset PRAM/PMU or something in minis too :) Just guessing...
  • »17.11.24 - 10:02
    Posts: 1390 from 2010/1/6
    Maybe internal battery is low - replace.
    Otherwise: Boot into OpenFirmware-Console and wait. If it does'nt shut down, it could be also an installation-issue of MorphOS.
    Or do you have a MacOS for testing?
    If it shuts down in OF you should download AppleSystemDiagnostic .iso (https://web.archive.org/web/20170309102920/http://dreamsupport.us/downloads/apple-mac/Apple_Service_Diagnostic_Disks_25_GB/)
    You need ASD 2.6.3
    Burn a CD and boot from it. After a while you will be able to do some HW-tests (follow instructions).
    Last but not least as mentioned above: PSU is dieing (Capacitors!!)
    [ Editiert durch Amigaharry2 17.11.2024 - 12:06 ]
  • »17.11.24 - 10:04
    Tom01
    Posts: 187 from 2009/9/20
    How can a PSU die, when it is not even alive?
    [ Edited by Tom01 17.11.2024 - 14:34 ]
  • »17.11.24 - 12:15
    Have you read initial post?
  • »17.11.24 - 15:55
  • phx
    phx
    Indeed, the battery is bad. I already noticed the bad date. Have to read it with NTP.
    Ok... it's basically what I feared: replacing the battery and/or cleaning requires to open the case.
    Haven't seen the shutdown today. Will watch it for some more days... ;)
  • »18.11.24 - 09:45
