enabling two (or more,if possible) monitors on dual G5 Mac with ATI Radeon 9800 pro
    Robertc85
    Posts: 10 from 2023/2/14
    hello still loving MorphOS although i haven't used it in a long time, now that i'm back to my g5 and everything (shuriken tiger, ubuntu linux, morphos 3.18 and hopefully soon sorbet leopard) is freshly installed i was wondering if there's a way to have both screens operational outside of the OS X based systems, (it doesn't even work in linux yet) but i use morphos more than linux on this computer anyway. what's the best way to enable 2 monitors if not more as the dvi port on my gpu is dvi - i type and i have a dvi to dvi + vga adapter. i'd be happy enough just with dual screen display for now though.
  • »25.05.24 - 17:04
    Posts: 2496 from 2003/2/24
    Dualhead support is restrained to specific GFX cards so without knowing what you have we can only guess.
    A quick check is to have two monitors connected and then go to Prefs->Screens, create a new one and see what modes are available.
    [ Edited by Kronos 25.05.2024 - 21:09 ]
  • »25.05.24 - 17:09
    Robertc85
    thanks i will try that next time i am booted into the OS but i am using a radeon 9800 pro i believe, it's got 1 dvi out and 1 adc out and 256mb of video memory
  • »25.05.24 - 17:18
    Posts: 3232 from 2003/3/5
    Anything VGA is unlikely to work in dualhead.
  • »25.05.24 - 17:45
    Well ADC is really DVI+power+USB so that would not be an issue.
  • »25.05.24 - 17:58
    Yes but if he uses a dvi to vga adapter to utilize the analog bits of the dvi, that will not work with MorphOS.
  • »25.05.24 - 23:50
    Robertc85
    the vga portion was going to be used under linux but that isn't working either, i have two digital screens one works in morphos, the other in linux, they both work together but only in mac os x i'd like to get them both working in all 3 systems if possible i may end up removing the y adapter anyway
  • »26.05.24 - 07:56
    @jaca
    Yeah, missed the part about the DVI/VGA splitter....
    @Robertc85
    If you have 2 digital monitors connected and go to screen prefs and press either "edit" or "new" you should get a list with supported screenmodes.
    They all should start with "Radeon9800(pro)" and if some have a ".1" appended you can select one of these to use the 2nd screen.
    Note, Ambient itself works on only 1 screen at a time, but you can create a 2nd "public" and move application like Wayfarer over there.
  • »26.05.24 - 10:11
    analogkid
    Posts: 703 from 2004/11/3
    I'm stepping in here for a dual monitor problem I have, too. My G5 has got a Mac Radeon 9600 (RV360) with AGP and 1xADC and 1xDVI connector.. In case a Cinema Studio display is connected to the ADC connector, the display at the DVI port (BenQ FullHD) isn't recognised anymore. In the prefs I get only the screenmode for the ADC display, no ".1" screenmodes.
    I guess the gfxcard isn't supported for dualhead support?
  • »26.05.24 - 13:05
    @analogkid
    When dualhead was introduced the list was this:
    - last (and 2nd to last?)gen PowerBooks with 128MB VRAM
    - iMac G5 (the only one using VGA for this)
    - the original 256MB 9650 found in the 2.7GHz G5
    AFAIK all additions were "upwards" hence not for 128/64MB 9600s.
    A complete list of supported cards would be nice though.....
  • »26.05.24 - 13:13
    This must be the BTO version that shipped the Mac while the one I "found" in my tech pile is a retail version, still Mac specific but with DVI/S-Video/VGA.
    Quick test with DVI and VGA in my QuickSilver G4 gave me a distorted image on both monitors with no .1 modes.
  • »26.05.24 - 16:17
    igracki
    Posts: 463 from 2003/2/24
    I found out that the second monitor must be turned on before booting the computer!
    But sometimes it also works if the monitor is turned on after booting;)
  • »27.05.24 - 16:36
    @igracki
    I'd guess that is down to whether the monitor still answers to DDC when in standby.
  • »27.05.24 - 18:16
