Corrupt text and images
    tolkien
    Posts: 583 from 2013/5/29
    Hello mates.
    I have had a few days to enjoy MorphOS but I have extrange artifacs in the system...Even in the OpenFirmware.
    Cleaned gfx card contatcs with IPA winth no luck.
    I upload a few images to can see the problem and perhaps someone can give me and idea to where to look at.
    System is a PowerMac g5 2Ghz with a 9600 Pro.
    [ Editado por tolkien 30.12.2023 - 20:52 ]
  • »30.12.23 - 18:52
    SkulleateR
    Posts: 77 from 2023/9/19
    Got the same System here with no issues ... looks like a slowly dying RAM on the gfx card :-(
  • »30.12.23 - 19:01
    tolkien
    Thanks for the answer SkulleateR.
    After cleaning gfx card, ram modules, mainboard i decided to replace a few capacitors from the gfx card and the thermal paste and seems it solved the problem.
    Lets see in a few weeks if my trusty solder skills are good enough ;)
  • »02.01.24 - 08:29
