Recent Video Drivers and PCIe cards on PowerMac 11,2.
    ernsteiswuerfel
    Posts: 570 from 2015/6/17
    Sapphire HD 5450, 512 MiB, SKU: 11166-01, VGA/HDMI/DVI-I, Generation: Evergreen
    Does not work on MorphOS 3.18 (screen stays blank).
     # lspci -vv -s 0001:06:00.0
    0001:06:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cedar [Radeon HD 5000/6000/7350/8350 Series] (prog-if 00 [VGA controller])
    Subsystem: PC Partner Limited / Sapphire Technology Cedar [Radeon HD 5000/6000/7350/8350 Series]
    Device tree node: /sys/firmware/devicetree/base/ht@0,f2000000/pci@3/pci174b,e164@0
    Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
    Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    Latency: 0, Cache Line Size: 64 bytes
    Interrupt: pin A routed to IRQ 65
    Region 0: Memory at 90000000 (64-bit, prefetchable) [size=256M]
    Region 2: Memory at 80140000 (64-bit, non-prefetchable) [size=128K]
    Region 4: I/O ports at 0000 [size=256]
    Expansion ROM at 80120000 [disabled] [size=128K]
    Capabilities: [50] Power Management version 3
    Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
    Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
    Capabilities: [58] Express (v2) Legacy Endpoint, MSI 00
    DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <4us, L1 unlimited
    ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
    DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
    RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
    MaxPayload 128 bytes, MaxReadReq 512 bytes
    DevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr- TransPend-
    LnkCap: Port #0, Speed 2.5GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <64ns, L1 <1us
    ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
    LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk-
    ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
    LnkSta: Speed 2.5GT/s, Width x8 (downgraded)
    TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
    DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP- LTR-
    10BitTagComp- 10BitTagReq- OBFF Not Supported, ExtFmt- EETLPPrefix-
    EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
    FRS-
    AtomicOpsCap: 32bit- 64bit- 128bitCAS-
    DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR- 10BitTagReq- OBFF Disabled,
    AtomicOpsCtl: ReqEn-
    LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
    Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
    Compliance Preset/De-emphasis: -6dB de-emphasis, 0dB preshoot
    LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete- EqualizationPhase1-
    EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
    Retimer- 2Retimers- CrosslinkRes: unsupported
    Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
    Address: 0000000000000000 Data: 0000
    Kernel driver in use: radeon
    Kernel modules: radeon
  • »24.09.23 - 13:19
    ernsteiswuerfel
    So, after I tested 4 cards on my PCIe G5 11,2 for the r600 driver the only working one was the Sapphire HD 4550 HyperMemory, SKU: 11141-06 (https://www.techpowerup.com/gpu-specs/sapphire-hd-4550-hypermemory.b348).
  • »24.09.23 - 13:22
    Posts: 1082 from 2003/3/24
    That's a little bit disappointing.
    I am about to get an HD 5870 for my 11.2 G5.
    And I have a working HD 4550 since last year displaying Ambient through HDMI in 3440x1440 in 32bit.
    And Mplayer is working and playing videos up to 1080p in window and full screen.
  • »25.09.23 - 13:57
  • man
    man
    Posts: 136 from 2019/11/11
    5450
    5870
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=12785&forum=53&start=7
    you certainly see that before
  • »25.09.23 - 14:38
    Posts: 12452 from 2003/5/22
    > [...] 5450
    While comment #9 in that linked thread says that HD 5450 works, comments #17 and #26 in this very thread say it doesn't. So compatibility seems to depend on the specific card, not just the Radeon GPU, as has been outlined there.
    > 5870
    HD 5870 is not mentioned in the linked thread.
  • »25.09.23 - 21:50
  • man
    man
    5450
    it was the same card i don t know
    5870
    why make this choice if not sure
    thanks
  • »25.09.23 - 23:20
  • man
    man
    that doesn't matter
    in fact (it's a develloper i think) tells that only the x1950 xt is the best card for the moment for powermac g5
    and not hdxxxx
    thanks
  • »26.09.23 - 02:34
    ernsteiswuerfel
    > [...] 5450
    Yes, I had a HD 5450 that worked once. Unfortunately I sold this card years ago when bigfoots r600-3D driver was not in sight.
    The two Sapphire HD 5450 I tried recently do not work. Also does not seem to be a simple memory size related issue to prevent r600-capable cards from working on the G5 11,2... The one HD 5450 got 512 MiB only and still does not work (despite my HD 4550 with 512 MiB works).
  • »26.09.23 - 07:52
  • man
    man
    ok it s more clear now
    thanks for answers
  • »26.09.23 - 08:13
    matt3
    Posts: 761 from 2004/2/10
    I'm pretty sure the results on a X5000 and PowerMac PCIe PPC will be different since:
    1. Bigfoot is developing on a X5000.
    2. The way PCIe is handled by both systems is different.
    Perhaps we can purchase Bigfoot a local PowerMac for him to test his drivers and donate to the MorphOS team to encourage the official support of these PowerMacs.
  • »26.09.23 - 09:16
    Yes, it's been well established that the PCIe graphics cards that don't work on PowerMac11,2 usually do work on X5000. ernsteiswuerfel (and others?) are in the process of finding a pattern regarding what it is that makes cards fail on PowerMac11,2.
  • »26.09.23 - 17:09
    matt3
    Recently either the little DVI to DP device failed (not showing green) or the DVI port in my new monitor failed.
    So I went back to a DVI to HDMI cable and it works perfectly.
    Is there a better standard to use? DP or HDMI?
  • »07.10.23 - 18:04
