Radeon HD 5870 Mac Bios
    Posts: 1087 from 2003/3/24
    Does anybody knows if a Radeon 5870 MacPro Edition would work with the OF in the G5?
  • »19.08.23 - 06:34
    Posts: 611 from 2003/4/11
    The last cards that did have a G5 compatible OpenFirmware BIOS were the Radeon X19xx cards AFAICT. The Radeon 5870 MacPro Edition pretty safely only works for Intel-based MacPro machines.
    It is also a pretty safe bet that none of the Evergreen based cards work for MorphOS currently (in a PMac G5), at least I didn't manage to run any of those which I have available.
    It is a different story for MorphOS supported machines like X5000 which run the BIOS code upfront.
    I still need to identify what the actual issue with PMac G5 machines is.
    I only managed to run some HD2xxx/HD3xxx cards on my PMac PCIe G5 so far.
  • »19.08.23 - 06:49
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    I had a HD5450 running in my PCIe-PMac G5 and my current HD4550 works too. A HD6450 I tried some years ago did not work.
  • »19.08.23 - 10:02
    Well, does it work in MorphOS as I don't care much if any kind of Linux works really ... ? I at least have several cards that don't and I still need to find a pattern why they refuse to work ...
  • »19.08.23 - 10:39
    Afaik the 5870 should run with the new driver that BigFoot has released some days ago.
    I have a Radeon HD 4xxx running in my PMac G5 Quad it outputs UWQHD through HDMI but has no 3D support.
    Ok i will go then for the 5870 non Mac Edition. I have still my Radeon 9650 that supports the OF.
  • »19.08.23 - 11:19
    ernsteiswuerfel
    Well, does it work in MorphOS as I don't care much if any kind of Linux works really ... ? I at least have several cards that don't ...
    Yes, these two work on MorphOS. Another HD6450 did not work in MorphOS.
    I sold the HD5450 but still have the HD4550 which I can put in for tests. Latest when bigfoots driver gets initial RV710 3D support. ;-)
  • »19.08.23 - 11:55
    ernsteiswuerfel
    You got a PCIe Radeon 9650 with Mac BIOS that works on a G5 11,2? I thought the only G5 OpenFirmware capable cards were the X1950 and the Nvidia ones??
  • »19.08.23 - 11:58
    Ok, good to know that it isn't some generic issue starting with R(v)7xx cards at least. It might be reasonable to collect some details for the apparently working and non-working cards.
    We should probably start to create a list of models/brands that supposedly work.
  • »19.08.23 - 12:03
    Posts: 12557 from 2003/5/22
    > to run any of those which I have available. […] I only managed to run
    This reminds me that last year I posted a small list of cards that had been reported to work:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=12785&forum=53&start=7
  • »19.08.23 - 19:01
    And it is still as useless as last year without any detailed info on memory size and/or vendor plus output connector options added for most cards to at least get an idea of what might be different.
  • »20.08.23 - 12:10
    ernsteiswuerfel
    So it's probably no disadvantage to have Linux running on the G5 and get the relevant data of cards working/not working on MorphOS via lspci -vv -s [busnumber] ;-) ^^
  • »20.08.23 - 17:51
    It's at least been useful enough to have known already last year that it's not true that "none of the Evergreen based cards work" ;-)
  • »20.08.23 - 20:59
    Sorry my bad. I Mixed that Up with my PMac 2,7 Ghz and AGP.
    OK gonna get me a Radeon 5870 from XFX and will tell you how it works. But not before September going to vacation.
    If you are looking for a good and fast Card that is supported by the new driver then get you the 5870. It's the fastest afaik. The 6870 is slower then the 5870.
  • »21.08.23 - 11:42
