Sil3112 on PowerMac MDD 3,6 with MorphOS installation
    fmatejic
    Posts: 5 from 2023/8/16
    Hello,
    I got and flashed a generic Sil3112 SATA controller from ebay with a Mac firmware.
    Now is controller visible in the Mac OS X Tiger, installation of OSX10.4 was successful on SATA disk, everything is perfect.
    But a MorphOS 3.18 installation doesn't see any disks on Mac, only a DVD (on internal controller), but the Sil3112 is in PCI Control Menu listing :
    Class : Unknown
    SubClass : Device Does Not Fit
    Vendor : 0x106b
    Device : 0x0033
    In installation is not detected.
    Is the Sil3112 supported on MDD in MorphOS ? Or is supported only on another Amiga HW.
    As I wrote, I have only one disk in my MDD on the Sil3112 with MacOSX running.
    I used common firmware 128K for Mac for flashing ...
    Thank you for any info about it.
    f.
  • »16.08.23 - 20:10
    Tcheko
    Posts: 540 from 2003/2/25
    fmatejic wrote:
    Class : Unknown
    Vendor : 0x106b
    Device : 0x0033
    This specific device isn't supported.
  • »17.08.23 - 03:42
    fmatejic
    Yes, indeed. This was clear from beginning.
    But the question was different ...
    1/ Is any SiL3112 on MDD 3,6 or 3,5 supported in MorphOS ? Or is supported only on another platform
    2/ and if yes, supported, which FW is used ?
    Filip
  • »17.08.23 - 07:14
    eastone
    Posts: 47 from 2007/8/4
    All firmwares should work in MDD. I have tested Seritek(3112), Wiebetech(3112,3512) and SIIG (3114) without any problems.
  • »17.08.23 - 07:33
    fmatejic
    Hmm, as I wrote, it is visible in OSX, and OSX is installed on the SATA and booting.
    But is not visible by MorphOS. Is possible to share/share link/info about 128K firmware ?
  • »17.08.23 - 07:57
    eastone
    All mentioned roms are visible in MorphOS either.
    Here you have few roms (big thanx to the dosdude1! for extraction and patching):
    https://dosdude1.com/files/macstuff/PCISataROMs/
  • »17.08.23 - 08:06
    fmatejic
    Ok, thank you !
    Non visible ROM in Morphos what I used:
    md5sum firmware.bin
    49b10717c65cc436f700648a8a28fb1c firmware.bin
    oc/strings :
    WiebeSATA3112 -> driver,AAPL,MacOSX,PowerPC
    16 June 2006
    date
    14:00
    time
    I will try to reflash it with the other firmware ...
    Thank you
  • »17.08.23 - 08:46
    eastone
    At the moment I have a controller installed with patched seritek firmware. Works perfectly in dual boot with Morphos and Fienix.
  • »17.08.23 - 08:56
    fmatejic
    I deslodered, flashed, soldered back the eeprom on SATA Sil with pointed firmware. Mac OS X boots normaly from Sata SSD, MorphOS same state ... no storage...
    Class : Unknown SubClass : Device Does Not Fit ... in PCI boot.
    It is strange because you reported that FW works.
    I changed disk from SSD Adata SU650 to some small rotation disk from NTB, what I have and it is visible in MorphOS, then PCI information about Class and Subclass seems to be irrelevant for reading disk in MorphOS. If disk is not recognized in MorphOS, then sata bus card is not displayed ...
    Ok, then this is now about looking for SSD disk which is visible in both OS, Mac + MorphOS.
    Thank you
    f.
  • »19.08.23 - 17:53
