-mouse
    bash64
    Posts: 974 from 2010/10/28
    on boot my mouse doesnt work so i have to unplug it from usb and reinsert.
    any ideas?
    maybe my mouse is cheap and generic and i need a brand name?
  • »10.05.23 - 19:11
    Posts: 1385 from 2010/1/6
    Cable or Wlan-Mouse? Here both works great.
    Check if mouse is recognized by poseidon -prefs (USB)/Devices as hid.class. (Wlan-Mouse is called "USB Receiver)
    If not: Change mouse!
  • »10.05.23 - 19:55
    bash64
    yes, its wireless.
    will check
  • »10.05.23 - 20:52
    bash64
    its hid.class wireless mouse
  • »10.05.23 - 20:53
    NewSense
    Posts: 1601 from 2012/11/9
    @ bash64 - Some of the later Apple wireless mice, and probably some of the cheaper/generic mice might be unsupported by the Apple hardware that MorphOS uses. I know I have a later Apple (Magic-type) wireless mouse (model number not to hand) that suffers/doesn't work because of this issue. :-(
    So, you might need an older wireless mouse to get it to work, though I've bought some cheapeer/generic mice and they have been OK. It seems to be good/bad luck if you come across one that is/n't supported or compatible with MorphOS, though there are some quoted in the MorphOS - Hardware Compatibility#Mice section that might be useful as reference to you in these circumstances. 8-D
  • »11.05.23 - 01:11
    bash64
    thanks
  • »11.05.23 - 02:22
    Posts: 477 from 2019/5/9
    any ideas?
    I had the same problem with wired mouse. I had to re-plug mouse after every reset, both on Powermac and Powerbook. If I swap the mouse for the not-so-cheap one, all works normally.
    So I have the same advice like others - change the mouse ;-)
  • »11.05.23 - 04:28
    bash64
    mcally mouse worked.
    strangely the ONN brand mouse from walmart does not.
    it acted up on boot but then it quit working altogether
    logitech didnt want to play nice either
  • »12.05.23 - 21:31
    NewSense
    @ bash64 - Which models (their model numbers) of mice did you try out that either did or did not work with MorphOS? :-?
    As the hardware compatibility list in the MorphOS Library could probably benefit from having the hardware added in there for other users to know what does/doesn't work with MorphOS. 8-D
  • »12.05.23 - 23:40
