Can't get VGA output out of my Radeon 9000 pro on G4 MDD
    Posts: 18 from 2017/10/7
    Hello! I am setting up my g4 morphos rig after a long time without using it. Yes, i know, shame on me.
    The other day i got a really nice sony CRT that fits very well with the computer. Sadly at the moment, i can't get vga output from the card. Before this I always used a dvi to hdmi converter with very good results. That still works. The problem is when i try to get video out of the adb connector with a vga adapter. Uboot works. Os9 works too. But no way for morphos to show anything on screen, either my hdd installation or the newest 3.17 iso that i've burned.
    Dvi to vga with passive adapter doesn't seem to work either.
    Any suggestions? It's been a long time and maybe I'm missing something...
    Thank you in advance!
    Edit: i forgot to say that i have already changed the display resolution on ambient to make sure that is compatible (1024x768)
    [ Edited by CMTX 14.03.2023 - 22:18 ]
  • »14.03.23 - 19:28
    Posts: 3274 from 2003/3/5
    Try the other output - it might work. If it does not, you are out of luck. We generally do not support VGA.
  • »15.03.23 - 10:52
