IMac G5 ISight Fan control
    Posts: 3 from 2023/2/1
    Hello,
    I'm running MorphOS on an IMac G5 ISight 20" (A1145) and it run very smoothly.
    I was wondering about one thing : the fans control/speed
    Actually even when the CPU temp is high, the fans are always at the minimum speed and CPU doesn't cool down. I tried the tool IMacFanCtrl by Frank Mariak and it works pretty well in order to cool down the temp but it is a manual operation.
    Do you know if it is a compatibility issue with this model of IMac or if it doesn't work at all ?
    Thank you
  • »01.02.23 - 09:25
    cip060
    Posts: 149 from 2010/7/30
    Same imac you can adjust by relaunching imac fancontrol and put what you like and save
  • »01.02.23 - 09:37
    cip060
    You have to find the right speed and the right noise
    now we are in winter but when summer arrives the temperatures rise
    read the readmi of the program and adjust accordingly
    In any case it works and you have to find the right relationship between cooling and fan noise
    Obviously you must also have the thermal paste in good condition
  • »01.02.23 - 09:40
    cip060
    This is a simple fan control/temperature monitoring tool for iMac G5 20"
    iSight running MorphOS.
    It allows you to manually control the fan speeds within its valid/reported
    range and view various temperatures. This is meant to be more of an
    experimental tool if you should ever experience issues with too high
    temperatures when running the system on high CPU load.
    While iMac G5 is not officially supported by current MorphOS versions which
    is 3.15 at the time of this release, future MorphOS versions might have
    better system integration and/or might require to get this tool updated if
    you still want to use it.
    If you encounter any issue, please contact me at frank@morphos-team.net
    New in Version 0.4
    - new shell/icon parameters
    MIN_RPM0 minimum fan rpm speed for fan 0 (optical fan)
    MIN_RPM1 minimum fan rpm speed for fan 1 (CPU fan)
    MIN_RPM2 minimum fan rpm speed for fan 2 (HDD fan)
    NOGUI do not open the user interface but only adjust minimum rpm
    speed if necessary, (only useful if any of the MIN_RPM
    args is used)
    Any of the minimum RPM arguments won't take effect if it is either out of
    the fan's own minimum/maximum range or below the actual current setting
    of the fan
  • »01.02.23 - 09:42
    Posts: 2564 from 2003/2/24
    There is only one model of iMac that works with MorphOS and that is „unsupported“.
    This status might change with a future release but till then Frank‘s small tool is the best option.
  • »01.02.23 - 12:25
    Ok thank you all for your answers.
    Yes I was thinking about something which could automatically manage those fans depending on the temp level but as you said it is unsupported for those iMac.
    Let's see in future releases.
    Cheers
  • »01.02.23 - 12:59
    Posts: 3311 from 2003/3/5
    Fan control for the iMac is ready and will be included in the next MorphOS release.
  • »01.02.23 - 14:09
    Great news ! Thank you very much
  • »03.02.23 - 09:58
    defender
    Posts: 249 from 2011/4/24
    It is always impressive to see the progress in development. Thanks a lot to the Morphos Team. Looking forward to test the next improvement!
  • »04.02.23 - 07:49
    defender
    (Double Post)
    [ Editiert durch defender 04.02.2023 - 09:52 ]
  • »04.02.23 - 07:49
    discreetfx
    Posts: 402 from 2003/7/26
    eBay linky please for G5 iMacs that will work. Nothing nVidia based right?
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »20.02.23 - 22:55
    matt3
    Posts: 784 from 2004/2/10
    Yes, must be Radeon... I think it was the last version of the G5 that works.
  • »21.02.23 - 02:46
    Posts: 1354 from 2004/2/8
    This one for example.
  • »21.02.23 - 04:24
    Nasty that one…..
    It is really simple: G5, 20“, webcam
    Only 1 model qualifies, and thats the one you want.
  • »21.02.23 - 06:47
    NewSense
    Posts: 1601 from 2012/11/9
    @ koszer - that does indeed look to be a good price for the A1145 iMac G5 2.1GHz 20 inch model - even though it's going to need a thorough disinfecting and fumigating to that keyboard, but it is an A1016 bluetooth keyboard that will work with MorphOS - if you dual-boot with Mac OSX installed and the keyboard 'paired' via Mac OSX's bluetooth stack. 8-)
    The iMac G5 1.9GHz 17" (iSight) PowerPC 970fx, Model A1144 (EMC 2081), iSight, PowerMac12,1, is (I believe) also partially supported, though this may also be improved upon in v3.18 (guess? :-?) but it is a step-down from the A1145 that I own, and know that works really well. 8-D
  • »21.02.23 - 07:09
    Except for the fact that the sellers seem to confuse the "iMac G5" with "iMac" and you can buy an Intel 2,16 GHz if you don't pay enought attention to the details.
  • »21.02.23 - 08:46
