USB Network.
    matt3
    Posts: 784 from 2004/2/10
    For the fun of it, I was going to try a Playable USB to Ethernet on MorphOS.
    Has anyone gotten them to work?
  • »07.10.22 - 17:22
    Furvert
    Posts: 83 from 2004/4/20
    I have an adapter that will be going on my A1200. I think I tried it on the Pegasos II earlier and it worked ok. You do have to watch for the chip type same as with scsi or sata cards. Right now both my A1200 and Pegasus II are down. (The Peggy won't post and the Ami needs hardware for the tower case) so I can't test that again. Though since all the systems (except the Amiga) have ethernet ports I don't know why you'd want to. The USB one is slower.
  • »08.10.22 - 12:54
