How to run MorphOS on unsupported G5 PCIe
    bigfoot
    Posts: 510 from 2003/4/11
    ASiegel wrote:
    bigfoot wrote:
    I'm also not entirely sure whether MorphOS will correctly use dual link DVI hardware on those cards.
    It has worked in the past with my Radeon 9600 Pro card if I used the first (or second) DVI port at least.
    Completely different hardware and completely different code paths, so unfortunately dual link DVI support on older models doesn't really mean much in this case.
  • »25.08.22 - 17:30
