Battery Indicator and sleep mode on iBook
    Elowan
    Posts: 214 from 2011/4/18
    hello,
    I wonder if there is a way to have a battery indicator and also a "sleep when laptop is closed" function in MorphOs, when running it on iBook G4?
    AFAIK there is no special or dedicated iBook version of MorphOS, or am I mistaken?
    Do I need to configure or install extra components to the system, to make things work?
    Cheers
    12" ibook G4 1.33Ghz, 1.5GB RAM, ATI 9550 32MB, 16GB SSD, WiFi, BT, ComboDrive
  • »15.08.22 - 06:26
    Posts: 2581 from 2003/2/24
    For the battery check the screenbar modules, rightclick on the screen-depth gadget.
    Sleep is not supported by MorphOS.
  • »15.08.22 - 07:45
    Elowan
    thank you !
  • »15.08.22 - 08:02
