Do-quiesce finished
    defender
    Posts: 249 from 2011/4/24
    Hi all together,
    I bought myself a imac g5 with a broken optical Drive. That is why i tried to boot from usb stick.
    The open firmware said loading Elf... Do-quiesce finished.
    As far as i understand umsd0: might Not be the right adress for Morphos to access the usb drive.
    That is why i need some help of others to find the right name in a g5 imac i-sight.
    Thanx
  • »27.05.22 - 08:55
    Posts: 3278 from 2003/3/5
    Umsdo0: is what you use to tell MorphOS to load an iso from a usb drive. Unless you have more usb drives connected, it will always be umsd0. ud: is what you need to tell the OF where to load the MorphOS’ boot.img from. Since you’re seeing the do-quiesce message, I’d assume that you got that bit right. Still, check that you are trying to load the boot.img from mac_ppc64 directory on the ISO and validate the path after umsd0:. Always best to make it short like umsd0:mos.iso or so…
    boot ud:\boot.img bi umsd0:mos.iso
    [ Edited by jacadcaps 27.05.2022 - 13:24 ]
  • »27.05.22 - 09:23
    defender
    Thank you, Installation completed 😁
  • »27.05.22 - 11:15
