Mini: Screen resolution of OF-Screen
    Posts: 1372 from 2010/1/6
    Could anyone check what the default screen resolution of OF-Screen on a Mini is? (Pixel and vertical/horizontal frequency).
    I cannot test it, because I've connected (HDMI) a Samsung UE32ES5500 (LCD-TV) and cannot see OF screen or early-startup-screen of MOS. Normaly this TV knows all VESA-Resolutions, so its a bit strange.......
    Btw: MorphOS itself, works, once fully booted, perfect!
  • »10.04.22 - 17:39
    Posts: 3278 from 2003/3/5
    Samsung vs mini is a known problem and afair it is due to the higher resolutions making it exceed its pixel clock. You fix it by using VGA or by using a different monitor.
  • »10.04.22 - 21:01
    Thank you! I was afraid about that.....
  • »11.04.22 - 05:20
    Posts: 603 from 2003/4/11
    Especially the DVI transmitter built into the PowerMac10,1 GPU (32MB VMem) is very picky about FullHD DVI/HDMI resolutions, MorphOS Radeon drivers have a workaround for this.
  • »11.04.22 - 06:32
    This TV has a (very) strange behaviour:
    Turning Mini and TV off for about 10min (plugged off socket-outlet) and restart again, OF-screen is shown for about 2 min! After that time, screen disappears and no signal-message is displayed (but signal from Mini is still there).
    That could'nt be normal.........
  • »11.04.22 - 16:15
