Radeon 4350 AGP running on G5
    Posts: 1086 from 2003/3/24
    I am trying to get my HIS Radeon 4350 AGP card to work under MorphOS 3.15.
    I get a picture but everything is slow like hell.
    In the Screenmode prefs i did disable the enhanced Display. So the drawing speed improved from slideshow to a fast slideshow. And the CPU usage is between 50% and over 90%.
    When it falls to 50% the drawing speed is much better, but not smooth like it shoud be.
    Is anyone else using a card like that in his AGP G5?
  • »03.01.22 - 17:18
    zukow
    Posts: 654 from 2005/2/9
    check debuglog
  • »03.01.22 - 21:30
    zukow schrieb:
    check debuglog
    How do i do that? Do i have to enable it first?
  • »04.01.22 - 21:16
    Posts: 3311 from 2003/3/5
    Run Sys:Applications/LogTool, it's on by default on Macs.
    [ Edited by jacadcaps 05.01.2022 - 00:17 ]
  • »04.01.22 - 22:17
    Ok finally i had time to check again and tried LogTool.
    It seems that the Radeon Card can't run in DMA Mode.
    http://PlayCloud-Jake.quickconnect.to/mo/sharing/eLFgRigbO
    [ Editiert durch ThePlayer 12.02.2022 - 14:55 ]
  • »12.02.22 - 11:57
    So my ISP have me back Online. My Server had a downtime the last 2 days.
    Any suggestions what i can do or whom from the MorphOS Team i should contact? Maybe Frank?
  • »15.02.22 - 17:18
